Hello all, has any one removed the upper speaker grills... sending them out to get coated very soon so any help is welcomed...
Printable View
On my 2020 RTL, I just grab the inside edge with my fingertips and gently pull outward and up at the same time; that should release it the tabs.
HI dave the inside edge near the cluster yes....
Yes, there are two tabs/clips on the inside edge that go into the console. Once those are released, the cover will lift and pop out.
ill try it again, its in there pretty firm,,,thanks
You can use a 90 deg. metal pick and pull it up using that. Some sets have a pick with sort of a semi-circle end. That works better.
