Based on the error code, I will attempt to replace the CAPS on my 2016 RT-S. I have located what I believe is the sensor. It looks like a small torx bolt that needs to be dealt with. Very limited clearance. I think I can cut the cable tie that holds the sensor lead and one other lead. However, I don't know if this will provide enough clearance for an allen-type torx key. Any suggestions for what to use?
Thanks
