Hello, I Lost my RH ACCESS COVER (OEM 708400257),
Does anyone know where I can get a used or less expensive one? The color is Steel Black. Can Am wants $214 (seems a little steep to me for such a small piece).
Jeff
Jeff
On my ride home from the dealership with my new 2022 F3-T, my left side cover came flying off. I stopped and tried to look for it in the near by field, but no luck. I called the dealership and they replaced it for free… They are poorly designed and shouldn’t come off so easily.
Hi jmack. If you want to try to find one used, here is the years and models that use that part. This information will help when you speak with the motorcycle salvage yards.
ASSEMBLIES WHERE 708400027 IS USED
2015 SPYDER F3 SE6 - Body And Accessories Console
2015 SPYDER F3 SM6 - Body And Accessories Console
2015 SPYDER F3-S SE6 - Body And Accessories Console
2015 SPYDER F3-S SM6 - Body And Accessories Console
2016 F3 000E6G - Body And Accessories - Console
2017 F3 000E6H - Body And Accessories - Console - Package S-Std
2017 F3 000E6H - Body And Accessories - Console - Package T-Ltd
2018 F3 LTD SE6 - Body And Accessories - Console
2018 F3 S SM6 & SE6 - Console
2018 F3 T SE6 - Console
2019 F3 LTD SE6 - Body And Accessories Console
2020 F3 LTD SE6 - Body And Accessories Console
2021 F3 LIMITED - Chrome Edition - Steel Black Metallic, (Built After Sept. 2020) - Body - Console
2021 F3 LIMITED - Dark Edition - Steel Black Metallic, (Built After Sept. 2020) - Body - Console - China
2021 F3 LIMITED - Dark Edition - Steel Black Metallic, (Built After Sept. 2020) - Body - Console - North America
2021 F3 LTD SE6, (Built Before Sept.2020) - Body And Accessories Console
2022 F3 LIMITED - Chrome Edition - Steel Black Metallic - Body - Console
Hello, Im so sorry for never thanking you all for your responses. I'm kinda new to this format and didn't know where to find these responses. THANKS all!
I had a surf around and found this site.
Not sure if its up and running, but it's there.
https://www.yamahapart.com/cart
Cover panels.
The link works but...
Good to know all this.
Had mine all apart for over a week. Parts I ordered still not in and Daytona calls so I put it back together. Took a full day to assemble what I had apart. Ride today on the interstate and I spotted my right-side panel flipping up and down. Pulled off and fiddled. No luck.
Wife got mad at me so I slowly went holding it down until getting off at an exit. Got off the bike and still struggled to get the darn thing to hold tight in the front. Crap design but finally it stuck. Over 100 miles on mine right now. The more I play with it the less I like it. Then also the far less do I like the supplier I chose for extras. LaMonster is NOT that suppler as they don't deal with what I wanted. Maybe that's why?
:oldpost::oldpost: I would hope by now he found his parts!!:popcorn:
sounds like a business opportunity if you have a quality 3D printer......
Leaders RPM has this:
https://leadersrpmshop.com/can-am-ne...nel-708400239/
They do not specify the color, but I'm pretty sure it is gloss black. You should call them to make sure it is the color that you want.
