I’m experiencing a noise and a wobble from my fly wheel. How can I fix this issue and what else should I be looking for to replace (i.e. teeth sprocket, belt, etc) ?
Flywheel? Do you mean a belt pulley?
When you write, 'fly wheel', what exactly are you referring to? The front Sprocket in its entirety; the harmonic balancer part of the front sprocket; or maybe the big drive sprocket at the back?? :rolleyes:
Have you lifted the back wheel off the ground, and with the ignition off, gently spun the wheel while you inspect both sprockets and the belt for any damage; missing or damaged teeth in either sprocket or the belt; &/or any 'out of true' alignment as the whole lot turns? Is the rear wheel aligned and the belt tensioned properly?? :dontknow:
Lotsa questions, I know; but answering them will help us to help you. :thumbup:
Yes, the front pulley.
I was referring to the front sprocket. I have not attempted to spin the rear wheel to see if everything is in alignment. But, thank you for the suggestions…
