Not starting after winter!! :(
Hi guys,
bad news for me yesterday... My ST-S Spyder won't start!!
I parked it in my garage in October and it was working fine.
Yesterday I tried to start it, and I just got "tic tic tic tic" but I didn't hear the starter trying to start the engine. So I jump it with my car (with and without the spyder's battery plugged) but still "tic tic tic tic" and the Spyder dashboard was reseting with every single "tic". Not a battery issue since it's making the same noise even without the battery.
I can hear maybe a relay but I can't hear the starter moving. I tried the drown mode, same thing.
Here are 2 videos, one is in drown mode, the other regular starts (2 shots):
Drown mode: https://youtu.be/4C7I_bPpU6g
Regular try: https://youtu.be/wQfxtWr4Q_g
I checked the fuses, all good.
So it could be the starter (but it was working fine in October!), or the D2 diode (again, was working fine in OCtober), or the engine is seized (why woudl it be???).
I have the technical manual of this Spyder so I guess I can test the D2 diode and the starter, but how to check if my engine is seized??
Since my dashboard reset everytime I tried to start, I suspect the engine is not the culprit, it might be related to something electrical...
I could need a little help troubleshooting this issue, if one of you has an idea... Thanks!
