Yesterday I had the opportunity to see and test ride the new 2020 RT. Here is a brief video that Mike Huber and I did on the new bike.
https://youtu.be/Je6lawi4BpI
Rob
Printable View
Rob
Thanks for the video Rob.
Yes, Thanks for the video, couple questions, I see you were comparing the 2020 to your 2015 RT. You mentioned you had Elka shocks. Do you also have Rons sway bar? Believe you said the it rode different. Could that be because you were an inch lower than your current RT?
Do you have highway pegs on your current ride? The new longer23" floorboards slant up at the front, could this replace needing or wanting a peg to push down on in turns?
Also If I could ask your height and sleeve length? ie: I am 6'1" with a 35" sleeve The reason I ask is because you said you felt pain in your shoulder blades from riding Mark Hubers RT. I know when ordering he said you could get a short, stock or long handlebar.
It looks like the rear case that is removable has a third brake light built in, is that right?
Thanks for doing the video:thumbup:
Thanks for sharing. If I knew you were going to have one there yesterday I would have called out sick from work and took a ride down LOL
I'm curious to see it in person, although I can't say yet if I would want one. Yes, there seems to be definite improvements in areas, but is it worth it? I can't say either way. Very cool though.
I missed it here as they had just driven off the dealership lot. Nice to have seen your video...:bowdown:
Thanks for the video!
Deanna
thank you for that preview. Did they say if they were going to any other dealers?
Yes I have Ron's sway bar. I did not do a long ride so don't read too much into my ride experience. I was very impressed that it was so much better than a stock RT with sway bar upgrade or Elkas.
I'm 5'8" and I thought the floorboards, brake, and everything were fine except I need the bars closer to me if I were to purchase one. I don't have highway pegs on my RT; just don't need them.
Mike wasn't sure which set of bars were on the prototype bike that I rode. BTW, I felt no pain in my shoulders, but I suspect I would have with a long ride as I know what reaching like that does to me.
Let me know if I've missed anything in my response.
Glad you got value from the video.
Rob
Yes, the rear topcase easily removes and has it's own brake light.
Paul, Mike was going to be headed to other dealers in CA I think. I believe he was then going to trailer to TX. He gave me his card. His name is Mike Huber and his number is 321 586 9354. Call him and you might be able to connect with him someplace.
Rob
Thanks for that information. Thanks again for the ride report, I am seriously considering a move to a 2020.
:coffee: Thanks for the information. I will wait another year and see what happens.......:thumbup:
Procurement Strategy: Looks like Can-Am has pushed the $4k rebate for 2019s til Jan31st; that matches the timeframe for a free extended warranty for a preorder 2020. Plan is to pit the 2020 RT against a 2019 F3 LTD - best test ride wins.
Thank you for the video. :bowdown:
Rob,
Thanks for your video. BRP makes a big deal that the 2020 is the result of a decade of RT riders' input. However, it has already been documented that they "missed the mark" in some areas(plastic links on the upgraded sway bar). You also brought up some negatives about the 2020 platform(interior dimension of side cases-old battery protrusion). Did Mike reply to your concerns?
Mike
Mike, I shared my comments with Mike while I was there with him. He didn't push back. What he was most uncertain about was the bars as he didn't know which set (near, mid, far) were on the prototype bike. He's assuming there will be three bar options like I believe there are on the F3.
Rob
Does the stock 2020 sway bar fit the 2018 rt ? And what shocks are on the 2020 ?
What i do not like about my 2018 rt is the unstable front end ,and no i do not have Ron's say bar.
I don't know the answer on the sway bar. As to the shocks, Mike said the name and I just don't remember. They are not Elkas and they are not the current RT shocks. Sorry, I just can't remember the brand.
Rob
My suggestion is to order BajaRon's sway bar and just be done with it. In the video, Mike Huber said this was very similar to the beefed up sway bar by Ron.:thumbup:
"click:https://www.spyderlovers.com/forums/...rs-amp-Helmets
The name of the front suspension are "Sachs Big-Bore shocks"
and the rear suspension is "Sachs shock with self- leveling air preload adjustment", for the limited RT
And yes Mike said he was told they were a little beefier.
Yes it is a decade of input from us RT owners, Heck I spoke with a design engineer back in 2012 at the Can-Am Spyder Owners event and discussed how I had made a significant improvement by adding works performance shocks to my 2010 RTS. Also remember him asking me about my floorboards, as at that time they only came with foot pegs. I explained that with the Seal floorboards allowed for giving me more foot and leg adjustments. This was a benefit but that I also used the board to steer the spyder by applying foot and weight pressure at the top of the board where it flared up in turns. You could take turns so much more aggressively. By then I had already had installed a custom Corbin seat with a back rest. I also shared that this helped lock me in to the seat. He was taking notes with a pad and pen. Having his attention I said that in California with all the crazy drivers my best safety upgrade was the third brake light . What ya know, now the RT limited's top case has a third brake light.......... So yes they hit the mark!
that's my"Timeless Black" in the photo above
currently have these boards
BRP had on sight techs from their factory repairing and fixing things for free! Yes they even repaired my throttle linkage thingy ( the part you twist with your right hand to go) ;)
I for one am so thankful they gave us a large two helmet storage case. And am happy they kept the side bags the same. Why you ask? Because my original luggage that came with my RTS premier edition had luggage included and All 3 still fit!!!:dg1:
Not sure what source you are getting documented info on a product that is not put out yet for us consumers, that so negatively puts them as missing the mark. Have read several of your other posts where you blast the looks of the spyder for all the black plastic. If we didn't have panels covering her up, then I feel she would look way more un finished. If you want to change something, and I know you do, by all your addons In your profile, :cheers: just paint as I did in the photo above the rear body matching tail. Also had several other parts painted to my liking. Have seen a white one done that way and it looks bad ass. Also if you pre order you will get an additional 2 year warranty.:ohyea:
.............. but with all that said, beauty is in the eye of the beholder.
just sayin
TicketBait
Last line sort of says it all.
Yep TicketBait, thanks for the reminder as Sachs is what Mike said.
Rob
