Need Help Hooking to Trailer Brakes - Solved!
I have searched this site, and found several helpful items, but not an answer.
Backstory: Friday I ordered a Time Out Deluxe camper. Monday I think I will call back and have the brake package included. My 2 other trailers are light and I have not had any stopping issues. My Discovery runs about 250 with all my camping gear. The Time Out will probably be slightly over 400, hence the adding of brakes.
My problem is deciding on a brake controller and the location it should be mounted. While familiar with their use, I have never had to purchase, install, or specify the specs for one. I’m confused.
I would think this is one case where size does matter. Mounting location could be a problem as the units have to remain dry and have to be oriented correctly.
The only thing I am reasonably certain of is I want proportional and not time based.
I need help on the following 3 things 😊
1 What unit to get.
2 Where to mount it on a 2019 RTL.
3 Can I hook the units sensor wire straight to the brake wire prior to trailer electronic isolator or will that cause the CANBUS to go crazy.
Any help with any or all 3 is greatly appreciated…………..thanks………..ed
