But unless you know the
WHOLE story Doug, new threads that only tell us
the latest part of an ongoing or an Owner induced problem can at the very least, be really difficult for others to provide/contribute anything useful!! :shocked:
I was looking back thru my notes on the problems I've encountered on my Spyder and those of others I've helped with, and I kept on running into the same few causes for this particular code coming up - damaged or clogged tone wheels; oversized/mismatched tires, particularly large rear tires, often also teamed with small front tires; &/or trying to make a different sized rear sprocket run properly on a Spyder that came with 'the other' rear sprocket size.... My notes suggest that it could be the number of wheel rotations reported to the ECM means the Gear info message calculated by the ECM ends up being too much different from the calculated gear recorded in the TCM (a calculation which AFAIK, uses engine revs, gear selection, the 'OEM sprocket & wheel size, & the indicated vehicle speed).
AND, my notes also show that often, Spyders with these issues would seemingly run fine for some time (albeit not usually
too long! :p), then 'something' (like hitting a big bump or doing a burn-out :rolleyes: ) would trigger the next spate of similar issues rearing their ugly head. :banghead:
So, I think it's important that at least the June thread and this January thread should be combined, even if simply for continuity's sake in following the progress of F3VE's battle with this particular code/issue, and I hafta ask:
Are you still running 20" rims F3VE, or even just non-standard tire sizes that are outside the '
known to work' 165/50R15 -185/45R16 front range &/or the 205/65R15 - 225/65R15 rear range?? :dontknow:
If you are, then I'd guess that a big part of your ongoing problem is going to be one of those issues raised &/or discussed above or in the earlier posts of this now merged thread concerning your ongoing issues with this code.... Maybe this bit is why you're still getting this code kicking up every now & then:
- Incorrect gear ratio;
- Gear info message from ECM is different from the calculated gear in TCM (using revs & vehicle speed).
Or maybe it's something discussed in this even earlier thread:
https://www.spyderlovers.com/forums/...-wheel-install
Or even something here:
https://www.spyderlovers.com/forums/...ss-fault-codes
But it's beginning to look to me that there's a good possibility that all of your ongoing problems with this particular code
juuust might be related to you running too much bigger rims &/or tires F3VE, or maybe to something you've done in an attempt to make it possible to do that, even if just for a short time... but I'm really just guessing?! :dontknow:
