2011 RS-S SE5 - DPS fault - is it stealing the power?
Hello there. I have a problem with the charging voltage, it happens like this: I start my Spyder, 12.2V at idle. If I turn the steering bar to the maximum left, 13.8V (normal voltage). If I turn it back to straight ahead, the voltage decreases to 12.2V again.
If I remove one of the three connectors on the DPS, I have normal charging volts, but errors appear on the dashboard.
Removing the DPS fuse does the same thing.
And if I take it for a ride this error shows up: Check DPS and VSS, and it enters Limp Mode.
I think that the DPS steals power... Any ideas?
