2012 Spyder RS SE5 showing P2545 and C0044 fault codes - help?
Greetings all. I'm new to the forum so pardon if this thread is placed in the wrong subsection.
Recently me and my dads shop recieved a 2012 Spyder RS SE5 for cheap that we thought would be fun to try and fix.
Previous owners have done some bad work on it which included breaking the "nipple" for the brake fluid pipe to connect on the brake-fluid reservoir.
We have fixed the issues we have been able to find but we keep getting two error codes that won't go away.
P2545 and C0044.
On the display it says "ABS FAULT" and "VSS FAULT" when we turn the ignition on.
Currently we're at a loss what could be causing this issue and what we should do to resolve this.
Things we have done so far:
- Replaced the broken brake-fluid reservoir
- Aired out the brakes and made sure there is no air in the brake fluid pipes
- Checked all the fuses that they are whole
- Made sure all the lights on the bike works
- Made sure we have enough brake fluid
- Unplugged the battery over night and plugged it back in the next day
- Done the reset with the brake pedal (hold it down, turn of the bike and turn it on again with pedal down) but the codes just come back when the BLS gets pushed in.
- Changed oil and filters
- Driven the bike around the block while it's in limp mode to see if it resolves itself
The codes show up as soon as we let go of the brake pedal and the BLS gets pushed up.
We even tried to move the brake pedal so that the BLS never got pushed up and then the faults never showed up and we could drive the bike no problem. It runs amazingly when the faults are not there.
Like I said we're at a loss what to do right now. This is the first time any of us work on a Spyder as we normally work on Harley Davidson bikes.
There sadly is no dealer or authorized workshop close to us that we can bring it to for diagnosis.
Sorry for the long post and I do hope that there is some solution to this problem as we have been working on this for two weeks now. And the two error codes we get are the last issue we need to resolve to get this bike back on the road.
