Fitted LED's, got the Hyper flash; now can't get front direction lights out! HELP?!
TRIED LAMONTSTER'S 'FIX' FOR DIRECTION LIGHTS HYPER-FLASH.....
https://www.lamonstergarage.com/hyper-flash-reset/
I installed LED lights in the rear, and those go crazy when I put on my turn signals.... The video that Lamontster posted either doesn't work for the 2019 F3S, or I'm at fault (most likely)....
I figured I'd just install some LED's up front to correct the issue... However, I'm at a loss as to how to access those bulbs???? I pulled the front wheels off, and there are a number of small screws which I removed (very loose from the factory, I might add) to no avail, the housing that holds the bulbs will not come out.... WHAT AM I DOING WRONG??
Has anyone got the answer??? Is a SPECIAL TOOL required to remove the front directional lenses?? HELP!!!
DAN P
SPYD3R
