Needing guidance on how to remove front fender. The issue is the cover plate underneath top of fender, on the under side of the turn signal housing is loose and rattling. Maybe lost a screw but not sure if it is broken? I can barely see it hanging under fender but tire is too close to get to it.
To access the cover I either need to remove the tire or the fender. Assuming the fender might be the easiest to remove? all comments appreciated.
