Took it for a drive on Skyline Drive, enjoying the warm weather and fall colors.
Oh we also got to talk to a Va. State trooper on the way home. He was a nice guy and let me off with a warning for acting not so smart.
Printable View
Nothing today...I put em both to bed last week after the fall storage ritual I do. 50's today, 30's for the forseeable future. Time to think snow and trail grooming instead.
Nothing my spyder is on a battery maintainer until April 2023.
Deanna
This morning I installed some black panel protection from "Wrap My Spyder". I used their Textured Carbon Fibre application. Peter's excellent installation videos really helped a lot. Some areas are a little tricky and I also had to trim a pattern in the Switch Panel kit for the Sea to Sky badge.
I think it turned-out pretty good. No more scratchy black panels.
Next will be Fobo 2 for trikes.
rode it for about 30 minutes....
Rode in a snowstorm in northern Nevada. Very slippy and slidey.
Did not do anything.
On the to do list, recharge the trunk gas spring, and make chassis adjustments to optimize the front suspension roll center. Gas Spring is easy, Roll center change will take some test riding along with having to get out the ROLO Laser Alignment tools and dial in the wheel alignment since changes to the front suspension will alter wheel alignment.
The last big change, relocating the ambient temp and pressure sensor along with intake air heat reduction is proving to be one of the best changes made to our Spyder.
Recently while on a night out dinner date, one Sena battery went dead. So while at dinner, I utilized the previously installed, for this exact reason, the Providence Spyder Accessories very cool, high quality switched USB charge port. Came out from dinner and had two Sena 20 setups charged.
Oil/Filter: check
91 ethanol free/Stabilizer: check
Battery Tender: check
Cleaned/waxed: check
Tire pressures: check
Exhaust plugged: check
Dryer sheets strategically placed: check
Covered up: check
Winter Hibernation has begun.
Will ride my two wheeler tomorrow for the 70* anomaly day in southern WI
Fixed the power port for my heated gear.
Checked the air pressure in the tires and air bag.
Installed my new F4 windshield.
Inspected the front sprocket for Red Dust - None found!!!
Planning a group ryde on Sunday - weather permitting.
As I have stated before; finding red dust is a sign of a possible bad sprocket. Not finding any IS NOT necessarily a sign of a good sprocket. Mine failed the inspection and had zero red dust. I know this has drawn out a long time with BRP but do not assume because you have no red dust that all is well. Might not be the case.
First ride since getting my Spyder back from warranty repair. Last week the avg temperature was in the 70s. This week is in the 40s, but I've been without the bike for 3 months and just can't wait for warmer weather.
I installed A Givi Trunk. Turns out my Spyder had, I guess the factory accessory removable back rest and also a luggage rack. I mounted the Givi Bracket on to the luggage rack/plate, following the Video put out by "Ask DIY Dad" back when he had a 2013. I could not figure out at first what the Plastic tail piece was for. But I guess that was the factory rear piece, that was removed to install the locking mechanism for the the accessories
Added some chrome trim from Wrap My Spyder to the rear top case of my F3L Special Series and went to the beach for a ride down the coast in SoCal.
Mine is sleeping for the winter
Installed a battery maintainer.
Unfortunately, both the Spyder and Ryker have settled down for a long winter's nap.
I just installed my Baja Ron Bar. It will be in the high 50's the day before Thanksgiving and Thanksgiving. Taking a ride to test it out.
Last week I installed the short reach bars that I bought from one our forum members.
Over the weekend we had a snowfall of just over 15” which has disappeared this morning.
Today I went for a ride on our local country roads including the Niagara Parkway.
The bars have made a major difference for me in seating position as it moved me further back in the saddle.
I can now use the backrest and my knees are now in a better position.
Just for reference, I’m 5’-6” about 150#
Very satisfied. Cheers all and an early Happy Thanksgiving
Though I just yesterday put my Gold and Black Anniversary Edition RTL in it's winter storage
I ordered several new farkles for the future, Got several Cyber Monday (or Black Friday continued) sale prices on
Spyder Accessories RT Front Grills 2 RT Logos - Carbon Fibre Black
Spyder Accessories RT Series - The Floating Pegs - Black with Black Edge
Spyder Accessories RT Series - Black Carbon Polyurethane Windshield Blackout
TRICLED’s Wide-Vu Convex Side View Mirrors
How's that song go??? "Anticipation......":2excited:
Not actually today but did finish repairing the parking brake mechanism on Saturday after I botched the job of putting things back together properly on the last tire change a few weeks ago. I had failed to get the base plate of the brake caliper properly seated over the pin in the frame and the first time I hit the brakes, it flipped around and destroyed the cable and pulley as well knackered up the micro switch. I managed to unfold the little metal arm on the switch without breaking it but had to purchase new cable and pulley. The process required removal of most of the right-side body panels and some very tight working conditions to reach everything. Took a few hours, but I gotterdone! :ohyea: Also installed new rear brake pads while I had it all apart again.
I installed a Lamonster Garage replacement brake rod on my 2022 F3L Special Series. The original is ridiculous and unsafe. I almost ran the first stop light I came to on my way home from the dealers with it. What a difference Lamont's made. Easy 10 minute install.
