Originally Posted by
PMK
Mike, for many years, I have read your replies and reasoning in regards to using 87 octane fuel, regardless that the manufacturer, whether determined by Rotax, the engine designer and manufacturer, or BRP the vehicle manufacturer, determined their reasons to state in manuals and placards to burn higher octane rated gasoline.
While I do respect your decision, and may not agree with your ideas, your recent reply post of a few days ago had me consider your words and challenge.
Your words put forth a request that a person that stated running high octane fuel, provide data to prove a need for the higher octane rated fuel.
After considering your words, it seems more applicable that those folks deviating from the manufacturers recommended fuel octane, they should be providing data, with repeatable results, demonstrating no harm to the engine in any way, or performance loss, over the wide and varied ways these machines are utilized.
BajaRon made some very good well accepted criteria where a lower octane may be acceptable, essentially higher altitudes, with less density, ultimately reducing the engines cylinder pressures. Myself, I have never accomplished testing to get a cylinder pressure value from compression testing a good fresh 1330 that is properly broken in. Cylinder pressure, along with other factors, some by mechanical design, others by mapping of the fuel and ignition, plus fuel quality must “play” well together.
As I mentioned, after considering your words for a few days, I hope the lower octane fuel causes no concerns for anyone electing to run it. Modern vehicle engines and the systems that support them are very smart, far more intelligent than the high performance V8 engines with points or no map style electronic ignitions.
Simply not sure whether you or BRP is more correct, but it would be very cool if you had data to support the running of lower than specified octane fuel.
