Nothing is ever that easy
Yea i got the brake failure message and checked the brake fluid it looked a little low. I added a little and still had the message so i added a little more and i still had the message. Now its up to the bottom of the cap and still have the message. I checked both sensors to make sure there was no damage and the connections to make sure they were connected. I pulled the the code C1282 that just says low pressure in brake lines and to check for leaks. Done that, no leaks i've driven it around for two days now with brake failure message and there in no loss of brake fluid in master cylinder so whatever im not taking it to the dealer unless brakes stop working.
