Results 1 to 25 of 39
    Aug 2016
    Pembroke, Massachusetts
    Default F3L windshield recommendations
    Looking to replace stock windshield for 2016 F3L .
    Your experiences with different windshield's would be very helpful.
    I'm 5ft 7 and like to look over the windshield. I've seen the F4 and Madstad online.
    Jun 2010
    Las Vegas
    I have the BRP Tallboy Mid Height and I like it. If I hadn’t gotten such a good deal on it I would have purchased an F4 Customs instead.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Aug 2016
    $485 on BRP spyder site.
    They are all expensive.
    Harrington, Australia
    They are ALL slightly different, RNBOB. If you can tell us what was wrong with the stock screen, and what exactly you are trying to achieve with an aftermarket screen, we can probably assist.
    Pete.
    HeliBars Handlebars
    Kenda Kanine rear.
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by RNBOB View Post
    I got that windshield from my dealer for $350.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Aug 2016
    Pete.
    I'm having head buffeting above 70. Would like it quieter for rider and passenger. Also some hand protection. Little more protection from cold. Planning on riding till snow falls.
    Thanks Bob. Replacing the stock screen was that first thing I did after having to get my wife to pop my eyeballs back in after the 3 hour trip home from the dealer.
    I can only speak for the F4 and the Madstad on my F3-L, but I found the Madstad too stifling around the hands/cuffs in the Aussie summer, while the F4 has cutouts. It sounds like the Madstad might be more what you are after if you want more cold weather hand protection. On the other hand, the F4 provides great all round protection from general buffeting, which is why I have gone with it, as there is a LOT of me to buffet. I have the F4 25”, but I am quite a bit taller than you. The top of the screen is about level with my lips, so I see over the top easily, and the wind hits the very top of my helmet, right where my Shoei has its air vent......perfect. F4 also has a great site where you can see and measure exactly which height screen will work best for you. Another huge plus of the F4 (especially for me), is their hardness. You can pull into a service station and wipe and dry the screen with water and paper towels, which you can’t do with others.
    Below is a photo of an F4 overlaid over a Madstad. The F4 has the wider top and the cutouts at the bottom. Another plus for Madstad is that it has mounts which allow you to move the screen up/down and tilt. This was no use to me with the Madstad screen as I had to have it on max height anyway, so I drilled a couple of extra holes in the F4 and mounted it on the Madstad brackets. It now works a treat, but it’s an expensive way to do it
    Hope this helps a bit. Both these screens are excellent, and I know there are others that people swear by.
    HeliBars Handlebars
    Kenda Kanine rear.
    Aug 2017
    Washingtonville, New York
    Default Road testing the F4 tomorrow
    Just installed the F4 23" V&T tonight. Looks great. Got it from http://www.sidsmotorcycleworld.com/ for $399 with free shipping and vet discount
    Aug 2016
    Quote Originally Posted by steveschumannss View Post
    That's a great price. 23" how tall are you? I would need the 21" I think. Did you get a vent or none? After going to the site I know what V&T means. Vent and tint. Did you have a coupon code when you ordered it online?
    Aug 2016
    Thanks, great info. I think I like the idea of a vent to open in the summer. Can the madstad be adjustable enough to keep you cool in summer and warm in fall/spring?
    Jun 2010
    Las Vegas
    You can get it for a lot less than that. Look up the part number on the BRP site then google it and you’ll find it for less.
    2010 RT- 622
    I can’t see why not, Bob. I got the F4 because I am 6’7 with a 54” chest, so I need all the coverage I can get to avoid being blown off the F3 . The Madstad has around 3” (going by memory) of up/down movement and a couple of inches of forward/back.
    The only issue I have with the Madstad is the one I mentioned earlier of it restricting airflow up my sleeves in the hot Aussie summer.......Also I would have to say that the vent I have in my F4 makes no noticeable difference in my opinion. You get enough venting from under the screen. I wouldn’t bother with one again.
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member MagYukon's Avatar
    Sherbrooke, Qc
    I'm 5'11" and had the tall boy on my F3T.
    Too much head buffeting and all kind of bugs directly on my face.
    I tried the 20" Madstad and ended-up returning it for a 22" (by the way, excellent service from them).
    The main reason I went to Madstad was the possibility to adjust it in height and angle. As I cannot test all of the possibility of aftermarket windshield, I went to the one that offer more flexibility.
    The 20" was about the same thing than the BRP tall boy in heights. Which wasn't doing any good for me.
    The 22" is perfect. Actually, it is configured to the highest position at the middle angle and I'm all covered. Looking just a bit over the windshield.
    In summer, I will be able to lower it of about 2" and also change the angle.
    So far, I like it a lot !
    X-Grip Ram Mount Phone Holder, Lamonster Fog and driving lights, BRP Heated grip, Home made rear rack + Shad SH58X top case, BRP belt tensioner
    2016 F3T , Red
    Jun 2015
    Midland, TX
    I have the F4 Custom 21". I'm 6' tall and don't like looking through a shield. The main reason for going with the F4 Custom is that it's wider than stock. I wanted to block the wind off my elbows which can jerk the arms some and reverberate down to the hands and the handlebars. I didn't get the vent as there is more of an opening at the bottom of the shield than on the RT. I did go with the tinted shield.
    May 2013
    Apex, N.C.
    I say do a search on Ebay. I purchased one exactly like the F4, 23" shield about 3 weeks ago. I bought it for $145 shipped. I was told that it was not an F4, but who cares. It works great, and I am not out of a ton of money. I will only be using it during the winter months, as I prefer the lower stock shield for warmer months.
    There is one exactly like it on Ebay now for $249.95 shipped. BTW, I used it last week at the Maggie Valley spyder rally, and loved it. I will post pictures when I can.
    Aug 2017
    Default F4 23" V&T
    6"1" with 32" inseam. The wind just clears the top of my helmet. Didn't do much for the hands. Very nice this morning when the temp was 36 degrees. My eyes see about 3" over the top of the windshield. Call sid at 877-229-6123. That was the veteran price
    SpyderLovers Sponsor
    Nov 2012
    Twinsburg, Ohio
    Default F4 Customs Windshields
    Aug 2016
    Quote Originally Posted by F4 Customs View Post
    Are there any forum member or veteran discounts?
    Aug 2016
    Has anyone tried the new show chrome windshield. It looks like the least expensive choice $180 compared to $350-400.
    Aug 2016
    After measuring like they show on F4 video even the 21inch would be too tall for me to look over.
    The Madstad 16inch looks like it may go low enough. Not many choices for 5ft7 rider.
    Not many choices for the 6’7” rider either, Bob
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member Spider-man's Avatar
    Mar 2017
    San Antonio
    I'm curious about this one too.
    May 2013
    Apex, N.C.
    I bought mine on ebay, and not sure who it is by. I was told at the spyder rally in Maggie Valley that it was by show chrome. Either way, I loved it. I also bought one from them for my 2014 RT when I had it. Great shield at a good price. You get what you pay for, but more isn't always better. I would recommend them.
    Aug 2016
    Do you have any pictures?
    May 2013
    Apex, N.C.
    They are not the best pictures, but this is all I have for now. I paid less than $150 shipped.
    I typically do not like taller windshields, and the stock one works good for me. But I wanted something taller for the winter months.
