Results 1 to 12 of 12
    Jul 2022
    colorado
    Default Replacing Camshaft Sensor - is there enough clearance for allen key type torx?
    Based on the error code, I will attempt to replace the CAPS on my 2016 RT-S. I have located what I believe is the sensor. It looks like a small torx bolt that needs to be dealt with. Very limited clearance. I think I can cut the cable tie that holds the sensor lead and one other lead. However, I don't know if this will provide enough clearance for an allen-type torx key. Any suggestions for what to use?
    Last edited by Peter Aawen; 03-13-2024 at 07:27 PM. Reason: Expanded title to briefly ask the question... ;-)
    2016 RT-S SE6 White
    5000 miles
    Sep 2016
    Chillicothe, Oh.
    2015 RT , Black
    Feb 2012
    Spring City,Utah
    They should if they will fit in the space given. You said you had very limited clearence and those look a little long. Have you tried them yet? When I have a tight clearence I have a 1/4 drive set I can use or a long torx bit that reaches out past any obstruction with a bit driver. Try what you have and see if it will work. That will give you an idea as to where to go.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jul 2022
    colorado
    I think long torx bits will hit the oil filter. I am thinking maybe something like this would work, but I don't have one to try:
    https://www.harborfreight.com/8-piec...4aAq4gEALw_wcB
    2016 RT-S SE6 White
    5000 miles
    Nov 2013
    Central Texas
    Quote Originally Posted by drgw222 View Post
    I have had one of those for years, and it is great to get into some really tight spaces. I wonder what a dealer uses to change the sensor.
    Jul 2022
    colorado
    Smile
    Quote Originally Posted by oldguyinTX View Post
    That's what I would like to know.
    2016 RT-S SE6 White
    5000 miles
    Jul 2022
    colorado
    Here is an update. I loosened the bolt with a T27 torx key. It came in at an angle but got the screw started. The screw is a 6 mm with an 8mm hex head and a T30. The connector had oil in it. I ordered a replacement which had too small a hole for the 6mm screw. But while I had the new one, I weighed it and the unit I removed from the Spyder. One I took out was 30.3 grams, and the incorrect replacement was 26.3 g. I doubt there was 4 g of oil in the sensor?? Anyway, I cleaned the contacts on the one I removed and put it back in. The Spyder runs fine so far. Screen showed the P0340 and P0000. After a ride, both fault codes disappeared. I just received another replacement from China and it looks to be all one-piece plastic, while the one I took out looked to have a metal body for part of it. Perhaps the all-plastic will not leak?
    It is difficult to find magnetic susceptibility for motor oil because it depends on additives among other things. However, oil has virtually no effect on magnetic fields, which is probably how the sensor works. But oil is not conductive either, so I am surprised that oil on the contacts would be a problem either.
    2016 RT-S SE6 White
    5000 miles
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    I'd use the ratchet, but use a higher quality 1/4" Torx bit, not the cheap Harbor Freight ones.
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
    Mar 2021
    Maryland
    Even though the oil may be non-conductive any contaminants or metal shavings in the oil can be conductive.
    2020 F3 SE6
    2020 F3 , Black
    Quote Originally Posted by CloverHillCrawler View Post
    True dat!
    I've seen the oil stream draining out of the sump plug visibly deflect almost an inch when a strong magnet was brought near!! (IIRC, it was one of the early development Magic Mirror Mount magnets, so the term 'strong' isn't really doing it justice! )
    The magnet didn't even touch the stream of oil, but there was enough magnetic contaminant/wear material suspended in the oil that whenever the magnet got within a couple of inches, the whole stream of draining oil was pulled waaay out of line... It was a very good way to prove the point that the engine really was badly worn & in need of a rebuild; altho in retrospect, it would've been a LOT smarter if I'd done that particular demo at their place rather than when their vehicle was parked on my brand newly laid concrete floor, cos it did cause the draining oil stream to miss the catch pan & make a real mess!!
    And I've still got that oil stain out there, despite some years of trying to clean it off!
    That particular oil probably would've served admirably as a rail gun conductor, it was that heavily contaminated & so highly conductive!
    Mar 2022
    AZ
    What were the first indications of a CPS problem and did it stop normal operation of the bike? Where is the sensor located on your bike and what panels need to be removed to clearly see the part? Did you check for a BRP replacement part? What is the info on the China part you found that fits and where did you order it? Thanks
    Oct 2022
    Jacksonville, IL
    When my CPS failed I got the dreaded Limp Home message. in checking for codes it was the same P0340. In checking with Can-Am Partshouse it stated that the part number was changed to a new part number. I called the dealer and after they read back the part number and it was the new number I had them order it and in came in about 2 weeks. It was the new one piece plastic. The one that failed was made in Mexico and don't remember the nationality of the new one. This happened in August 2023 when the RTL had 34,000 miles on it. I was able to ride it about 50 miles to get it back home. The bike seemed a little sluggish and I did not push it.
    2016 Spyder RTL SE6
