Page 1 of 2 12 LastLast
Results 1 to 25 of 32
    Jun 2017
    Nashville
    Default Hot while Driving 2014 RT
    My wife really gets hot while driving 2014 RT Spyder. My question is there any modification to increase airflow on the driver. I really don't want to remove the windshield unless that is something that is easy to do.
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    I’m considering Baker air wings. I agree that it does get toasty behind the windshield.!!
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Centramatic wheel balancers on the front and rear.
    Rivco dual flag holder
    Tricled mirror turn signal indicators
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lambskin seat cover from Smokey mountain sheepskin.com
    Tricled 360 degree led Headlights
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Spyderpops bumpskid w led light
    Rivco brand footrest
    spydermanexhaust.com exhaust
    had my exhaust installed @ Spyder in the hills.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Rich55 View Post
    You can start by adding a vent to the windshield. Like this one; https://www.amazon.com/dp/B00GUJAUUU...v_ov_lig_dp_it
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Some folks have had their windshield shortened, or they buy a shorter one.
    2014 RTL Platinum
    Aug 2013
    SF Bay Area
    I removed the two side shields that are just under the mirrors. It allows for more air flow to me and into the vents going into the engine area. I also have a shorter windshield.
    2021 F3 Ltd , Magna Red
    BRP's adjustable lower air vents...
    Jun 2017
    Nashville
    Default Hot Driver
    Quote Originally Posted by Dmetcalf View Post
    How hard was that vent to install?
    Dec 2015
    Oakley Utah
    I have not installed one, but there are plenty of folks here that have.
    Try this thread for starters: http://www.spyderlovers.com/forums/s...indshield+vent
    2014 RTL Platinum
    Aug 2015
    Canton, Ohio
    [QUOTE=Rich55;1372260]My wife really gets hot while driving 2014 RT Spyder.
    There re are a lot of hot women on Spyders!
    Joe
    Idaho
    Baker Air Wings plus the BRP adjustable deflectors plus the windshield vent are about as much as you can do. If you have an after market wide windshield go back to factory wide. I have the F4 wide and tall and it does cut back on air flow on me. The three items above help a lot but I've considered having my windshield cut back to OEM width.
    2014 Copper RTS
    Nov 2014
    TriCities, WA
    I have never had a heat issue, but I added the 2013 scoops, couldn't tell any difference, but it had to make it better, I also have the vented windshield and baker wings.
    Jun 2010
    Las Vegas
    Baker Air Wings with the BRP adjustable wind deflectors is a definite must have. Is your wife riding with the windshield all the way up? If so have her try it in a lower position, ideally with the top of the windshield even with her nose.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Invalid Emails
    Oct 2013
    Dardenne Prairie, MO
    Default Baker Air Wings
    I had them installed and they are well worth the cost. Use for cooling in hot weather, help keep warm in cool weather and help keep dry in light rain.
    2014 RTSS , Cogna/ black
    The windshield vent does a lot more to reduce buffeting; than it does to increase airflow...
    But it's still going to help!
    Active Member viperryder's Avatar
    Oct 2011
    Ohio
    Default BRP scoops
    I have a 2014 RTS and have added the BRP air scoops. These are the ones under the mirror. It has taken away all the heat from the glove box and the foot area. They are black in color don't look bad. Hope this helps.
    2011 RT-S SE5 Viper Red
    2014 RT-S SE6 Cognac
    Bajaron sway bar w/ aluminum heims
    Custom Design HM Brake light
    Custom Design Red front fender lights with turn signals
    Lidlox
    Corbin arm rests
    2014 RTS SE6 , Cognac
    Jun 2017
    Texas
    I just ordered some Baker air wings yesterday..! Should help a lot. They are a bit pricey but I’m sure the quality is there..!
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
    Jul 2015
    Dorr, michigan
    These are available on ebay for $140.00, so about $40 less than what the dealer wants for them. Take out the two screws on the factory deflector and install the new one with the same two screws. You will not believe the difference in the amount of air you can direct onto the rider and passenger.
    https://www.ebay.com/p/219400362-Can...2057037&chn=ps
    2020 RT Limited , Petrol Blue
    Northern Kalifornia
    Default Stay cool for sure......
    Get your lovely partner a cooling vest. Mine works very well. I have the kind I fill with about 16/20 oz. of water, however I don't get wet. It will last 2/4 hours depending. Love it, love it, love it! I got it from Silver Eagle Outfitters.
    https://www.webbikeworld.com/silver-...g-vest-review/
    Jun 2010
    Las Vegas
    Those are great in dry climates but don’t work so well in humid places like TN.
    2010 RT- 622
    Aug 2007
    Boerne, TX
    Come to south Texas, nothing helps....my buddy wears a cooling jacket with frozen pouches and he likes it. I may get one too.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by SpyderAnn01 View Post
    That's the conclusion I have drawn from the many discussions on this topic.
    It seems that in humid climates the best way to cool the body is to increase the air flow over the skin, so the suggestions about getting a shorter windshield, adding Baker Air Wings or the BRP adjustable deflectors are all good. Of course, well-ventilated riding gear is essential, also.
    2014 RTL Platinum
    Northern Kalifornia
    I'm sure you would know. I've never been east of the Mississippi on a bike. Thanks
    Jun 2017
    Nashville
    Default Hot 2014 RT driver
    Sorry, I can't figure out how to reply to a post without my original post. To answer your question about where the windshield is positioned it is just barely raised from the bottom. so where on this blog it was stated if the windshield is all the way down it had a tendency to break the mounting bracket.
    Dec 2015
    Oakley Utah
    Just go to the post you want to reply to and hit the button on lower right that says 'reply with a quote'
    The windshield is designed to operate at the full range of motion without breakage. That happens with oversized windshields at the high position in extremely gusty or bumpy road conditions and is RARE I believe. I've never had a problem with either of my RTs, including my wife's which has an oversized F4 windshield.
    BTW, windshields themselves are very easy to remove and install, so you may just want to get a shorty windshield for the really hot conditions you're experiencing and keep the OEM as a spare or for touring.
    2014 RTL Platinum
    Nov 2015
    Minnesota
    I just put the 2013 air flow vents to my 2014. This definitely reduced the heat of the seat. I did have the BRP adjustable air deflectors under the mirrors and I thought they just deflected the warm air coming out of the vents onto me. I also have shortened the windshield. I'm not a fan of Baker Air Wings but that might be the next step.
