Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
  1. #26
    Apr 2016
    Atlanta
    Quote Originally Posted by camam View Post
    I did all that and still said DONE!!! and it really comes down to hardware so...
    JL Audio here I come!!! Please fix my 2018 RT Limited!!!
    I installed 5.25 component speakers up front (perfect setup) and 5.25 coaxials in the rear.
    I used a JL MX500 watt to drive everything.
    This system is the best I’ve ever heard in a spyder.
    500watts of JL power is amazing and plenty to keep up with the harshest winds.
    I did have to cut away some of the rear mount areas with a Dremel.
    The system looks completely stock. Factory grills are all in place the only only “tell” is the JL badge i put over the BRP logo
    just below the safety card.
    Don’t let anyone tell you “you can’t do that” because i’m living proof you can.
    Also I shut off the “auto” volume leveling feature it made a big difference on my JL system.
    BRP should be ashamed of the audio system they put in a 30K bike.
    If your like me all the software upgrades in the world will never satisfy our audio file ears.
    Good luck...
    Where did you get the signal for the amp? Looks like the 18 and up the radio is in the cluster. looking for the wire colors.
  2. #27
    Active Member Frostbyte's Avatar
    Nov 2019
    Florida
    I quit messing with sirius altogether. I have my phone paired to my RT and run the Pandora app and listen to the stations I built up...Best of all, it's free. ;-{D
    2019 RT Limited , 2" Pedal Extender W/Oversize Pedal Phoenix Orange
  3. #28
    May 2014
    Texas
    I would like to change out the OEM speakers on my 2018 rt limited - any suggestions?
  4. #29
    May 2018
    Jacksonville, Florida
    I have a 2018 RTL and was having a time getting the music loud enough to hear at highway speeds. I went through the music settings and found the audio volume control low, medium and high settings. I turned it to high and now I only have to turn my speakers up to just under half way and it is pleasant to listen to when idle and it seems to get louder as we pickup speed which is weird but we like it. It is now loud enough for any speed. I hope this helps as I just found this and worked with it. Yes, I read the manual and it doesn't ay much about the 3 levels at all, normally I don't mess with the sound system of any vehicle I have as they seem decent to listen to.
    Thank you,
    Ray B.
    These are the states I have driven my Spyder Rt Limited too.
    Mudflap -- Walmart
    Tricled Headlights and Fog lights -- valueaccessories.comRimsavers -- RimBladesUSA.com
    Showchrome Tiregard (TPMS) -- motorcycleid.com
    Front and side grilles -- CanAmSpyderAccessories
    Passenger arm rest -- Diamond R Accessories
    Rear axle caps -- Lamonster
    Magic Mirrors -- Lamonster
    Yellow and red running and blinker lights on fender --Show Chrome
    TRUNK-MOUNTED, DOUBLE FLAG HOLDER -- Rivco
    Rear Brake light for trunk -- Custom Dynamics
    Bumpskid w/led lights -- Spyderpops
    Seat cushion -- Airhawk
    Cup holders -- Drink2Go
    Ultragard-4-457BK-Black-Cover-Spyder -- Big Bike Parts
  5. #30
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by Daddyray View Post
    ...found the audio volume control low, medium and high settings. ...it seems to get louder as we pickup speed which is weird but we like it.
    Most touring bikes and most current cars have the same feature. It raises the volume of the radio the faster you go to compensate for louder wind noise, engine noise, etc. Low will only raise the volume a little, high will raise it a lot.
  6. #31
    May 2018
    Quote Originally Posted by MONK View Post
    I didn't know that but I was wondering if some of the people on here talking about how low the volume is if they knew the feature was available.
    Thank you,
    Ray B.
    Mudflap -- Walmart
  7. #32
    Active Member bcraig's Avatar
    Apr 2019
    Grove City, OH USA
    Good luck...
    Can you post the model number of the new speakers? Thanks
  8. #33
    Dec 2013
    Quote Originally Posted by bcraig View Post
    Looks sorta like camam only ever made that one post and hasn't even visited the Forum since Sept last year, so holding your breath for a reply from him might not be such a great idea! Sorry!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
  9. #34
    Jul 2021
    Camden County, South Jersey
    Default specs
    Quote Originally Posted by dbroadbent View Post
    Do you have any instructions on how to upgrade the amp/speakers? Thanks in advance!
    Do you have model # of speakers to use /amp. i have 2021 RT Limited, the radio sucks
  10. #35
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Quote Originally Posted by ENGINEER View Post
    The fix canam listed is for a 2018 - far different, I believe from a 2021 RTL. Also, better amp and speakers will do nothing for the poor radio, which seems to be imbedded in the LCD screen module. I added a better antenna (31") to my '21 RTL, which raised the FM reception from awful to poor.
    "Love 'em all.... Let GOD sort 'em out!"
    2021 RTL Dark Chalk Metallic with comfort seat
    1978 GL1000 w/'75 engine show bike
    1976 RD400c
  11. #36
    May 2021
    RI
    Hope this helps with those that use there Garmin GPS
    https://youtu.be/kN7LUflxlsU
Tags for this Thread
