Results 1 to 20 of 20
    Active Member SteveandBelinda's Avatar
    Jun 2016
    Canton, MI
    Default Changing out radiator Hoses on 2014 RTL
    Anyone got any info on changing these out?
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Quote Originally Posted by SteveandBelinda View Post
    A few years back I gave this some thought and I believe it can be done using " stainless steel corrugated " hoses like they use for automobile radiator purposes...… They are much stronger than the rubber ones ( burst strength ) are very, very bendable and have the added benefit of better HEAT removal from the liquid ( anti-freeze )……. I have seen 40-48 inch lengths for sale on E-bay for $36.00 ( and in different colors ) these can be shortened to the length you need …… Mike
    SoFlo
    Not sure what kind of info you need. As a side note, are you changing them as preventative maintenance or are you finding they have an issue?
    Jul 2010
    Las Vegas, NV
    We found a trick to install them: Goop waterless hand cleaner. Smear a bit of goop inside the hose, and the hose goes right on! If you have a hose that leaks, first try replacing the clamp. Fixed a leak on SpyderAnn’s RT.
    Joe Meyer
    Quote Originally Posted by cptjam View Post
    Any type of liquid SOAP ( which you probably have ) works great ………….. good luck …. Mike
    Jun 2016
    Canton, MI
    I am currently in Arizona, and it only leaks or drips when the bike has been hot, and then at night when the temps drop, it leaks overnight. You can see a drip on the lower hose where hose connects to the fitting that tees to both radiators. Took to dealer twice and he said it was from temperature variation, and some corrosion on hoses where connecting to fittings
    Jun 2016
    Canton, MI
    Dealer told me you would pretty much have to take off the frunk, and to replace both hoses and clamps would cost me about $1100. Bike has 32,000, and he suggested just changing them out.
    Active Member spyderfish's Avatar
    Jun 2014
    West Bloomfield, MI
    Had exactly the same problem with STS, even though they are different engines. Problem was solved by removing the spring clamp and replacing with screw clamp.
    The issue is probably getting access to the correct clamp. Access is much easier on STS. By the time everything is opened up, it is probably better idea to change out the clamps completely, as dealer recommended.
    2021 RTL SE6 - Marsala Red Blackout
    BajaRon Nosway Bar
    Front CentraMatic Balancers
    Value Accessories HandleBar Riser
    Brake LED Flasher
    Customized SmoothSpyder Tensioner
    Phone Phang
    Smart Mount Backrest
    LaMonster Mirror Locks
    Hopnel Frunk Bag
    Ultraguard Cover
    Active Member kdp1308's Avatar
    Jul 2018
    Wichita, KS
    Get some good heavy duty diagonal cutters and LOTS of hose clamps.
    I just read your posts #6 & #7 ….. you should probably read my previous post as to a solution …… or not !!!! ……………. But as far as the STEALER is concerned ………… When they look at you, all they are seeing is $$$$$$ ........ jmho ….. Mike
    Sep 2014
    USA
    I been wanting to try out this tool..Seen it at the bike show awhile back.
    https://clamptitetools.com/
    frunk is pretty easy to get off once you do it one time.. 1100 bucks seems really HIGH
    ....That's a pretty amazing tool ….. the only drawback that I see is - the amount of room you need to use the tool … ie. tight spaces could be a challenge ….. Mike
    Sep 2014
    USA
    Maybe at times it could be???
    Nov 2012
    North Las Vegas, NV
    You know removing the frunk isn’t that hard.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jun 2016
    Canton, MI
    Ain't that the truth
    Jun 2016
    Canton, MI
    I will have to see if there are any videos on taking the frunk off, out there
    I have a 14 also, and have removed my frunk a FEW dozen times, both lower side panels ( the ones that pop off ) have to come off …. four 10mm bolts across the top edge of the frunk ( you only need to put the outside ones on after first removal ) two upper side panel bolts 10mm and underneath two 10mm bolts that are horizontal into the frame …. NOT THE NUTS that are alongside the bolts ….. the most difficult part is the Rubber Elbo at the Air filter box …. getting it apart isn't difficult - getting it back together is ( that's why the dealer charges so much to remove & replace it ) ….. soooooo don't connect the elbo …. it isn't necessary …. it doesn't need to be airtight anyway …. The corrugated steel hoses I suggested ( earlier ) is an option IF the Hose/s have a pin hole leak -otherwise just replace the clamps ( with screw type ) as others have suggested . …. I can now do mine ( remove and replace ) in about 1/2 hr. …. find a parts fiche' and this will give you a good idea of the bolts etc. mentioned previously.... I have seen a few different vids ( like from shawn smoak ) of hoe it's done …. good luck …. Mike
    Jun 2016
    Canton, MI
    No, my concern, is how much is involved getting to them
    ?????? ……………… getting to " them " ….what are THEM ???? ………… Mike
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Joe can you dump the coolant buy pulling one of bottom rad hoses thanks
