Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Helmet security
    Mar 2019
    Las Vegas
    Default Helmet security
    Hi everyone.
    I am new to the Spyder.
    I just bought the RT Limited white/chrome.
    Other than carrying your helmet around is there a way to secure it on the bike?
    I tried the built in under the seat hooks but they won’t work with my Bell helmets.
    They won’t fit in any of the storage compartments either.
    Are there any aftermarket devices that will secure the helmet on the bike?
    I tried the search feature with no luck.
    and Help will come with information for attaching helmet.
    Nov 2018
    St Pete Beach
    Lidlox are one easy alternative. Go to Google and search for "Lidlox". Tried to add a specific link but gets censored............
    2018 RT , Asphalt Grey
    Nov 2018
    Waynesboro, PA
    2012 RTL , Brown
    Jul 2018
    British Columbia, Canada
    Get them here:
    http://www.lamonstergarage.com/can-a...air-lamonster/
    Copper, you beat me to it.
    2018 RT Limited , Champagne
    Apr 2013
    Somersworth, NH
    Lidlox are the way I went. Very easy to install. Available from Lamonster Garage and Spyderpops.
    Lin
    2016 RT-S Special , 2 tone black
    Mar 2019
    Las Vegas
    Perfect!
    What great forum!
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    Quote Originally Posted by VegasSpyder View Post
    Hi everyone.
    FlyBoy2121
    2014 RT ltd , original original Cognac
    Sep 2012
    Junction City, KS, USA
    Feb 2019
    Portland, Oregon
    I use a cable lock passed through the eye port of my FF helmet and the passenger assist bar.
    Oct 2015
    Lynden, WA
    I use a gun lock threaded thru the helmet D rings and secure to the passenger hand rails
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Haze View Post
    Good use for an otherwise useless thing.
    Bryant, Arkansas
    This may sound dumb............... BUT................. the two saddlebags on a RT are different sizes and a helmet will fit in one side but not the other, try both sides.
    Cruzr Joe
    Mar 2019
    Las Vegas
    Great ideas.. especially the gun lock idea... I have plenty of those laying around!
    Cruze Joe, I didn’t try all 4. Only the rear and the left side.
    I will try the right side... thanks...
    Thanks everyone.
    Active Member RTSJohn's Avatar
    Feb 2019
    Killeen, Texas
    Welcome to the parade.
    2014 , yes Pearl White
    Mar 2019
    Las Vegas
    Cruz’r Joe, you are correct. The right side is large enough to fit my wife’s helmet. Thanks for the tip...
    Also, the gun lock idea saved me $100+..
    But, the lidlocks are pretty cool.
    Jul 2014
    Mint Hill, NC
    I made two small, double ended loops out of plastic coated steel cable to fit through the helmet D-rings and use the OEM under seat helmet hooks; about 10 min work.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jul 2010
    Las Vegas, NV
    Front trunk (Frunk) and right side saddlebag. Gun locks, or, dog choke chain collars. Hook below the seat. Welcome! We are out of town, but will be home on the 12th. There is a Spyder group that meets at proshop in Henderson the first Saturday of the month. 9:00 am. The group is going to a poker run to benefit veterans. That starts at the Leatherneck club, Arville and Spring Mountain. Great run, great food, great band, great cause. Looking forward to meeting you! Joe
    Joe Meyer
    May 2012
    Panama City, FL
    , my shark evoline3 fits in the frunk (front trunk) Dale
    Feb 2017
    Hi everyone.
    I must be missing something. I wear an extra large Shoei and have no trouble fitting it into the right side "saddle bag" of my 2015 RT-S with the face shield facing forward and top of helmet facing outward. My wife can do the same with her helmet on her 2013 RT-L. We do have to remove the Sena 20S communicators but it's a minor inconvenience. We stuff them inside the helmet along with gloves and at least we know we're turned them off before walking away - usually. When we're touring with full bags we use cable locks through the eye port and the passenger assist bar as other have stated.
    Mar 2019
    Las Vegas
    Hi Arion, Yes. I assumed both side bags were the same size until another member pointed it out. I only checked the rear and the left side. I didn't know the right side is a bit bigger than the left. I can not fit my Bell XL into the right side but the Bell Medium will fit.
    A member mentioned gun locks as a way to secure them and it works perfectly too.
    Thanks.
    May 2017
    Boulder City, NV
    welcome from boulder city. Joe and Ann in vegas (Squared Away) can and will help you mechanically with your bike...very good folks
    Aug 2016
    Lake Villa Illinois
    Here's my solution: https://www.spyderlovers.com/forums/...38-Helmet-clip
    $5 worth of stainless steel, 1 hour of labor and it's nice to have a little project to work on.
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    I end up putting mine in the frunk, cuz it is too big with the sena on it, and my wife's goes in the right side bag, but updside down because it won't fit sena-wise either. They really should have made both the side bags big enough to fit full faced helmets. That and no front power/sound ports are my biggest complaints of the Spyder.
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    I just bought a large locking carabiner and small coiled steel cable. I can attach it to helmet rings and to the handrails on my RS. Or put the cable on the carabiner and then pass the cable through an open face shield. The cable also allows me to run it through the arm of my jacket to keep it from walking away, if I want to leave it on the bike. The whole setup is small and fits in my dash bag. Around 10 bucks on Amazon. I take the sena off the helmet and lock it in the frunk on top of whatever is in there if I'm on longer ride.
