Results 1 to 12 of 12
    Default An easy fix if your seat is too heavy for the gas shock
    Or if the shock has failed due to age etc. … years ago I wanted my seat to open more so I got rid of the Gas Shock and re-placed it with a shaped steel rod.... Got to my bio page and then to my Albums ….pics with explanations are posted …… Mike
    Pueblo West Colorado
    Great idea Mike! I added the utopia backrest and a full seat sheepskin cover on my RT however the BRP strut now can’t handle the extra weight. So It operates like a hood support being attached at one end and the other end goes into the hole you drilled in the seat pan right? Does it rattle when the seat is closed? Thanks for the idea.
    Quote Originally Posted by DesertSpyder View Post
    It isn't a tight fit so I imagine it can ….. but I have never heard mine, while driving …. and there is no evidence on the paint that it is moving around.... If you are still concerned, use a small rubber band and many wraps around the rod , it will act as a cushion …..I hadn't thought about this fix until you brought up the possibility ..thanks … I'm going to add this tonight …... Mike
    It's just as easy to go to an auto parts star with the OEM prop rod, and match it up to a aftermarket one with a stiffer spring!
    Really - and how much pressure does the OEM gas shock provide ???? ……………..Mike
    May 2018
    Chateauguay, Qc, Canada
    31 lbs is what I read somewhere here.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Sep 2014
    USA
    I got mine from rock auto holds up the seat very well. Old posts below.
    https://www.spyderlovers.com/forums/...ock+auto+strut
    I used one set for 30 psi, and it worked perfectly.
    (NOTE: My seat had a sheepskin seat cover, a BRP backrest, and a fuel door installed...)
    Active Member MonPaul's Avatar
    Feb 2019
    Central WI
    I have had the same problem since I put my backrest on.
    Just want to let everyone know that Rock Auto has them on wholesale closeout for $6.60
    https://www.rockauto.com/en/parts/st...t+support,1404
    Aug 2016
    Cleveland, Ga
    Try a Suspa C16-20651. It is a 40lb. strut shock and is 2 inches longer. Got mine on Amazon. Works great.
    The extra length isn't a problem?
    Get a stiff enough spring: and you've got an ejector seat!
    Jul 2017
    Indiana
    Quote Originally Posted by MonPaul View Post
    Thank you for the link, mine was getting a little weak.
    Saved me a bunch of money
    2015 RTs , Black
