Page 1 of 5 12345 LastLast
Results 1 to 25 of 109
Thread: 2020 rt
    Sep 2013
    Johnson, Vermont
    Default 2020 rt
    Dec 2015
    Oakley Utah
    They shrunk it. Saddle looks more sculpted. Nice evolution in the marque.
    Earlier model years should get a boost in resale value from this development I think.
    2014 RTL Platinum
    It will be interesting to see these in person. They did mention the base RT and the RTL would be about $1300 less than the current year. I like the no top box from the RT model. Looks are a bit different. Can't wait to see the new colors available.
    Enough to make me pull the trigger....probably not.
    Sep 2009
    La Valle, WI
    They shrunk it. Earlier model years should get a boost in value from this development I think.
    They said they lowered the seat but the driver has 2" more leg room and Passenger has 1" more leg room.
    2018 F3 Limited , Oxford Blue
    Active Member BryanSD's Avatar
    Jun 2018
    South Dakota
    It sounds like accessory add-ons will be more modular and similar to how you accessories are added to the Ryker. More DIY for those non-mechanics like me! I'd buy one!
    One question, does the wheel base look wider than the previous RTs?
    2017 Spyder RT Limited - Champagne Metallic Chrome
    - Wolo Bad Boy Horn, SPYDERPOPS Next Gen LED Bumpskid, SPYDERPOPS Double Vision Daytime Running Lights
    2021 Spyder RT Limited - Deep Marsala Metallic Dark
    - Replaced 2021 Stock Handlebars with F3 Stock Handlebars, BRP Adjustable Driver Backrest, Wolo Bad Boy Horn, SPYDERPOPS Double Vision Daytime Running Lights, SPYDERPOPS ""BRAKER BARS" Brake/Run Lights
    Jun 2018
    South Dakota
    BRP has updated their 2020 RT page: https://can-am.brp.com/on-road/model...spyder-rt.html
    Feb 2019
    Portland, Oregon
    Looks kinda F3-ish. Makes me wonder if they're discontinuing it. Finally, after all these years, all LED lights up front.
    Jul 2018
    Saskatchewan
    Nope......
    Active Member 3tracs's Avatar
    Dec 2007
    Solon, IA
    I like how that top case is removable. I'm kind of digging the redesign... It needed to be freshened up.
    Happy Former-Spyder owner!
    2008 SM5 PE# 3518 / Intense Blue Pearl (sold 2014)
    Greenville Tx
    The top box is better than the F3 even though it looks the same.
    2017 F3 Limited
    Jun 2019
    North Carolina
    In the trash can, it was. They spent about 5 mins on the Spyders and only 2 at that. No mention of any engine changes. Very short and simple. Was very upset with the outcome.
    Active Member CentralCoastCA's Avatar
    Aug 2012
    Santa Barbara County, CA
    Intriguing.......might be saying bye-bye to my ‘14 RT
    2020 RTL SE6 Asphalt Grey
    2014 RT SE6, Pearl White 57k (2014-2020)
    2008 GS Premier 17k (2012-2014)
    Greenville Tx
    The top box is better than the F3 even though it looks the same. LED headlights.
    2017 F3 Limited
    Greenville Tx
    Not too crazy about all the straight lines and the front end.
    2017 F3 Limited
    Greenville Tx
    115 hp
    2017 F3 Limited
    Aug 2013
    SF Bay Area
    Larger trunk capable of holding 2 helmets. Adjustable floorboards. No mention of the dash.
    2021 F3 Ltd , Magna Red
    Greenville Tx
    Looks like an FT and F3 limited only on the next level of luxury.
    2017 F3 Limited
    Greenville Tx
    The top box is got gas shocks and a stronger lid with metal hinges. No more flimsy lid.
    2017 F3 Limited
    Aug 2013
    SF Bay Area
    Can't get a look at the dash and they offer a Garmin GPS. No radio, no anything about music or entertainment.
    May 2017
    Mesa, Arid-Zone-A
    Whew...... I thought they might have come out with a higher performance shaft drive that would make my bike obsolete. Looks like same-ol-same-ol cosmetic upgrades. No reason to jump to the "new" stuff...... Jim
    Semper Fi
    Shrunk ??? ….. specs say 4.5 +/- longer ……. Mike
    Aug 2013
    SF Bay Area
    They will have the new Tech dash but more storage. The rider part of the seat flips up for gas letting the passenger stay put. Adjustable floorboards. Removable trunk.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    I find it interesting. I sure hope they did a better job with the top case, frunk and side cases over what they did with the F3.
    2020 RTL SE6
    May 2013
    Apex, N.C.
    I like the looks of this when the trunk is off. Nothing that I would switch up for, but the larger saddle bags (larger than my F3T) are nice. I also like the larger frunk.
    Jul 2011
    Mitchell, Ontario, Canada
    So they now put the RT on the F3T/L chassis with a different set of body work. The old RT chassis was introduced in 2013 and was the same as the RS and ST. So I guess time to go.
    2018 F3 LIMITED
