Results 1 to 6 of 6
    Apr 2017
    Pittsville Maryland
    Default 2015 SST Coolant Leak
    Rode SST all summer - no coolant drop, has been sitting for 2 months now has puddle of coolant on rt side in frt of foot rest-also did this last winter- rode 9 k this summer all good - no leaks ? Ideas?
    Sep 2019
    Cold Lake Alberta
    could it be leaking from the overflow tank? possibly crack in the hose to the rad.
    Cracked reservoir tanks are not un-common ….. A loose or not properly put on, coolant Cap has been re-ported more than a few times .… IMHO it is easy to get it on wrong ….. good luck ….. Mike
    Aug 2019
    Charlotte, NC
    I too, had the same issues. After removing all the panels to expose the radiator hoses, I found that the factory installed hose clamps allowed leaks at the radiator. Changed the factory clamps for worm gear clamps and fixed the problem.
    Clinton, MS
    Quote Originally Posted by dsteve931 View Post
    Good old cold weather leak at the clamps. The first year we went to silicone hose on about a hundred trucks it was like a mechanics circus tightening clamps.
    Active Member ARNIE R's Avatar
    Mar 2017
    Leesburg, VA
    Get rid of the factory oetiker clamps and replace them with worm screw ones.
    2014 ST-S Cognac
    2014 ST-S , OEM Yes Cognac
