Results 1 to 16 of 16
    Mar 2020
    South Jersey
    Default Axle Plug and Rust treatment Information for Can Am Ryker
    This is my first time posting something so please forgive any mistakes. Home Depot sells plugs (Stoppers) that fit into the Ryker front and rear axles. The brand name is Everbilt. For the front wheels you will need part number 755 651 (1-7/16 in x 1-3/16 in). This for the outside. For the inside (or back of the wheel) you will need part number 755 780. The rear wheel only needs one plug which is part number 755 651. So you would need a total of five pugs (Stoppers). Now for rust in the axles. Loctite sells a Rust Treatment Neutralizer that turns rust black. This is not a rust preventer only a neutralizer. It will take two to three coats for the rust to turn black. (follow instructions on the label) You can then paint or leave as is. If you do not have rust in the axles then wipe them out with a oiled rag and plug them. As I said before this my first time posting. I will attempt to attach pictures to this post so you can see what the plugs look like on the wheel. Wish me luck. Correction: The above numbers are not part numbers they are Store SKU numbers. When searching for the plugs on the Home Depot web site you have to list the following. Everbilt 1-7/16 in x 1-3/16 Black Rubber Stopper. Everbilt 1-5/8 in x 1-5/16 in Black Rubber Stopper.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by Earp View Post
    Great information.
    I believe I will be making a run to Home Depot in the near future for some plugs. I haven't driven mine in any rain yet so I don't have any rust yet.
    Great info .... annnnnnnnnnnnnnnnnnd .......... Mike
    Mar 2020
    South Jersey
    I tried to attach pictures of the axle plugs on the wheels but failed. Maybe I will get it right this time. There is also a cap you can make to attach to the plug. The caps are hard sliders used for tables and chairs etc. You have to remove the backing from the back of the slider and replace it with Industrial Strenght Velcro. You must clean the top of the rubber plug with alcohol before attaching Velcro to it. You can then paint them any color you like. The Sliders are sold at Home Depot. The Brand name is Everbilt. The part number is 192 193 (2-1/8 in). They come in a pact of four.[ATTACH=CONFIG]179562. Correction: The above number is not a part number it is store SKU number. When searching the Home Depot Web Site you have to list the following. Everbilt 2-1/8 in Hard Sliders.101_0024.jpg
    Mar 2020
    South Jersey
    I almost got it right.[ATTACH=CONFIG]179564
    Mar 2020
    South Jersey
    Mar 2020
    South Jersey
    I think I got the hang of posting pictures. This will be the last one. Once again please forgive the mistakes I am new at this.[ATTACH=CONFIG]179566
    Jul 2010
    Las Vegas, NV
    That works, too! 35mm plugs.
    Joe Meyer
    Jan 2018
    NH
    love it!
    Active Member a99miata's Avatar
    NW Florida
    Don't get mad at me if you don't like my answer.....
    Mar 2020
    South Jersey
    When using the Home Depot web site to search for the Rubber Plugs you have to list the following. Everbilt 1-7/16 in x 1-3/16 in Black Rubber Stopper. Everbilt 1-58 in x 1-5/16 in Black Rubber Stopper. The numbers I thought were part numbers ( located on the upper right hand side of the package) were Store SKU numbers. Sorry for the mix up.[ATTACH=CONFIG]179581
    Active Member Elwood58's Avatar
    Mar 2012
    PHOENIX Arizona
    Store SKUs work on the website as well.
    2012 Viper Red RT-S (Sold)
    2020 Ryker Rally
    2023 Plasma Red F3 Limited
    Jun 2019
    Florida
    Did you have any problem with the lug nut retainer ring clips that protrude into the center of the axle?
    May 2019
    Illinois
    Great info. Picking up my plugs tomorrow.
    Mar 2020
    South Jersey
    Not really. Just take your time to work it past the clip.
