Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Default BRP Shaky Mirror Fix for 2020 RT and F3T/L
    Sean Smoaks posted this video with part numbers on fixing the mirrors, https://www.youtube.com/watch?v=xGRw...ature=youtu.be. The repair starts around the 9:00 minute mark in the video.
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Member Cumberland's Avatar
    Jun 2020
    Manchester, Tn
    Looks like an easy enough mod.
    Sep 2017
    Durham,Maine
    Looks like a great fix, to bad the other pin isn't bolted also, but it should work!!
    2012 RTL , Pearl
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    $75 for what should be free. Or not needed if they were designed properly! Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    Maybe Joe and Ann will come up with a fix for less $$$ like they did for the F3T and Ltd.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Danbury Connecticut
    Quote Originally Posted by Tango View Post
    I agree, $75 is WAY too much money. If they included it with the original machine, it would be more like $5.00 additional.
    I did Lamont's fix. It cost about $8.00, but only because I needed to buy the tap.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Sep 2017
    Durham,Maine
    Lamont's fix is the cheapest way out, other than like said, the company doing it right the first time! But after watching some of the video's of that fix, where that bolt makes contact with the mounting plate in the back, it looks to me that there is rubbing going on where it is wearing it's way threw that plate! I was thinking when I saw that in I think it was Lamont's video that maybe a little gasket compound or gluing a small piece of rubber back there to strike agents would keep it from rubbing threw! Or maybe I am just trying to reinvent the wheel and it don't matter! Just a thought, some thing I picked up from the video, good luck guy's
    2012 RTL , Pearl
    Sep 2012
    Northern Virginia
    For those that don't have taps available, I found several drill/tap combo sets available on Amazon. I have a tap and die set but I may have to add some of these to my tool collection.https://www.amazon.com/s?k=drill+and...ref=nb_sb_noss
    [B]
    Jan 2020
    New York
    I ordered the parts earlier today. 62$ seems excessive, but i have seen that the screw fix eats into the bracket on the machine.
    708400550 x 4 - Brass Anchors
    207551044 x 4 - M5 Screws
    232561200 x 4 - Nylon Lock Nuts
    2020 RT Limited , ASPHALT GREY METALLIC - DARK EDITION
    Mar 2013
    Quote Originally Posted by YIRYDE View Post
    I have seen them at Home Depot also.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Feb 2019
    Portland, Oregon
    My Lamonster mirror fix was free as I already had the tools and lots of 1/4-20 screws. No more loose mirrors and no $75.
    My mama didn't raise a fool!!
    May 2016
    Vancouver Island, BC, Canada
    BRP has a mod kit out for 2020 RT and RTL - possibly F3's too (?). It converts the clip -on mirrors to bolt-on.
    Kit can be ordered from BRP dealers and is free of charge. Service dept. will install - takes around 10-15mins.
    Just had the work done on my RTL - mirrors rock solid now
    2023 900 Sport , Nitro Blue
    Danbury Connecticut
    I posted this in another thread. After about a month of riding with Lamont's fix, the mirrors started to shake again. Not as much as the original problem, but still troublesome.
    I found that the metal screws threaded into the plastic plate had started to back out.
    I'm not sure how well Loctite would work with plastic, so I added teflon plumbing tape to the screws to tighten up the threads and then reset the screws.
    If I have any issues with the screws striking the mounting plate, I'll just add a small piece of metal.
    IBA #47122
    Oct 2016
    Sebring, FL
    AT my 3K mile check, I'm asking my dealer to do the fix. I don't have a problem with it now, but time will usually bring out the problem.
    Active Member WingmanRT's Avatar
    United States
    Quote Originally Posted by ThreeWheels View Post
    Good to know. Right now (1 day in) it is rock solid, but if it starts to shake, I now know what to do. Thanks!
    Paul "Wingman" Metheney
    2020 Can-Am Spyder RT Limited
    2020 RTL , Red
    Jul 2010
    Las Vegas, NV
    Quote Originally Posted by JKMSPYDER View Post
    We have beta tests out in the field. Waiting on feedback. Much less than BRP! Joe
    Joe Meyer
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Quote Originally Posted by ryu1867 View Post
    Got a part number???
    2020 RT Limited , Marsala Red
    May 2016
    Quote Originally Posted by Jetfixer View Post
    The set for each mirror has three BRP part numbers, but don't have them.
    The upgrade kit the dealer ordered came with two sets, enough to fix both mirrors
    Feb 2016
    That's what I was hoping for, the kit number so I could refer my dealer.
    Danbury Connecticut
    Is there a number for this kit ?
    I've got my dealer looking into it, but so far they're unaware of it.
    EDIT....Ummmm....................Nevermind.
    My dealer just found a "TST" ?
    They are ordering the parts and I'll have the conversion made as soon as they come in.
    Thanks. I love this site !
    And BRP also gets Kudos for lisntening to it's customers.
    IBA #47122
    Mar 2013
    Maumelle, AR
    What is a TST?
    2020 RT Limited , Chalk
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    I'm guessing you mean a "TSB" or Technical Service Bulletin? That's a common term in the auto industry.
    Bob
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
    Jul 2010
    Las Vegas, NV
    It is, but it is not a warranty item. We tried, but the dealer won’t pay for the fix. We have had a fix in the works for months. After several tries, we developed the SAMS. BRP will sell you the fix. For less than half of their price, the SAMS is available now, and any owner can install them using the tools in the stock toolkit, and a pair of pliers. PM, email or call to get your SAMS kit, today! End that shaky mirror problem!! Joe
    Joe Meyer
    Feb 2019
    Portland, Oregon
    I'm curious as to what SAMS looks like. Got photos?
