Results 1 to 10 of 10
    Jul 2020
    Florence, sc
    Default How to remove the quarter turn cover latch on access panel F3
    Im fixing to get a few pieces wrapped and would like to take the quarter turn cover lock (part number 708400065) off the Access panel before it is wrapped. I tried to remove it with a little force but was wondering if there is a trick. I notice on cheapcycleparts that it is 2 separate pieces (quarter lock and the panel itself) so i know you can replace the quarter lock but does anyone know how to remove the lock? I tried pushing straight down while the panel was upside down but i didnt want to give it all my mite. And please before anyone says "Search for it" as said in other post i have read it have searched and the search query is not all that great. Reminds me of the programs we design at work
    Dec 2013
    Sorry, can't help with removing the lock; but if you are having issues with the search facility here (& I hafta agree, it's not great! ) you can always just add 'site:spyderlovers.com' to the end of your search string in google etc.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    I've got the access panels wrapped too, you need to put quite a bit of force to click them out, it's easier to put them back in tho.
    Excuse my bad English, am from the Netherlands and new to this forum.
    It's just clicked in, with a sort of collapsible ring.
    2019 F3s , O.E.M. Black, Black, Black
    Jul 2020
    Florence, sc
    Thank you piratezz
    Jul 2010
    Las Vegas, NV
    Push hard. They just click in and out.
    Joe Meyer
    Sep 2020
    Woodstock, GA
    You need to distribute the pressure evenly.
    Lay the latch upside down on a hard work surface.
    Lay the panel upside down on top of the latch.
    Note the alignment of the small latch tab with the curved slot in the panel.
    Place a large socket (like 17mm) on the latch area.
    Push on the socket. Hard.
    2015 F3-S , Steel Gray, Silver, Black
    May 2015
    San Antonio Tx
    Where can I find the access panel door round latch? I have one that broke off and the panel went flying! Panel was okay (few scratches), but the lock is now broken. Anyone know where I can obtain another latch?
    2021 F3T-LTD , Light Blue
    Vermont
    Quote Originally Posted by Sammie View Post
    HI Sammie,
    What year is your Spyder?
    Sorry I cannot help you with your access panel on your F3.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Dec 2013
    HI Sammie,
    Deanna
    You really should check the date Deanna... (and duncan ) of the last few posts, and the post starting the thread. Sammie started this thread back in September 2020, and last visited the Forum in June 2021....
    So there's a good chance that you won't get a response from Sammie, sorry.
    Member LesGrossman's Avatar
    Apr 2024
    South Central PA
    https://leadersrpmshop.com/can-am-ne...nel-708400238/
    Access Panels are part #708400238/239 for Left/Right sides. Look at the parts diagram... you'll see the twist-lock listed as a seperate part. I just bought 2 access panels, and neither came with the locks. They do ineed have their own part number.
    And as other said, they snap in/out. You just need to make sure the locks are turned so the tabs and keyways line up (look on the underside of the panel and the lock)
    2021 F3-S , No No Gray/Black/Orange
