Results 1 to 6 of 6
    Jan 2017
    Northwest Indiana
    Default Turn signals not showing on the dash??
    I washed my 2020 rally. The turn signals work but don't show on the dash. I sure think they use to. Any ideas what could be wrong? I need to go to the dealership for the wheel nut recall soon anyway.
    Member ravensrest's Avatar
    Feb 2021
    Grants Pass, Oregon
    I don't know specifically what is wrong, but, yes, your turn signal indicators should show up on your dash as a blinking green light. Since the problem occurred after you washed your machine, it's natural to think water got into something. It is also possible that you broke a connection somewhere. Start by letting a fan blow gently into the dash area over night; that may dry out any water. Unfortunately, you may have permanently damaged something too, and that won't be cured by drying. A trip to the dealer would be necessary. Not much help, I'm afraid, but it is a place to start.
    BS
    Quote Originally Posted by ravensrest View Post
    BS
    If it turns out YOU and WATER were the problem, and You have to pay to fix it, I would do what 100's of others here have done .... just add LED's to the mirrors, and tap into the OEM turn signal wires..... they work much better the the OEM set-up ..... good luck ..... Mike
    Jan 2017
    Northwest Indiana
    Thanks for the suggestion. Ryker is still under warranty and I would think the dash should be at least water resistant.
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    Was it a hand wash or a power wash? I.m not trying to case trouble, just avoid it .
    2019 Ryler Rally , Shock Yellow
    Jan 2017
    Northwest Indiana
    Sorry for the late update on this. I had installed a slingmod elec outlet bracket a while ago. Turns out that if you move your handlebars to the forward most position you can completely hide the turnsignal dash lights. Another example of ryker being fine and just user error.
