Results 1 to 8 of 8
    Dec 2019
    Kapolei, HI
    Default Baja Ron--Ignition Wires/plugs
    Got upgraded ignition wires and plugs from Baja Ron. EXCELLENT!! Cured low speed/RPM stumble which had previously defied resolution.
    HIGHLY RECOMMENDED. HERE's his page.
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    What yr and model do you have?
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
    Dec 2013
    Quote Originally Posted by Bangorbob View Post
    From another thread:
    Quote Originally Posted by PhilY View Post
    On my 2012 RSS, .....
    And I think this thread:
    https://www.spyderlovers.com/forums/...ssues-no-start
    is discussing at least part of the 'previously defied' RPM stumble referred to.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jun 2018
    Pahrump NV
    Thanks Peter. I thought I read somewhere that if you are changing the oil, it might be a good idea to change plugs and maybe the wires. If I read the website, there are no wires for the 2016 1330. Correct?
    Mar 2015
    forrest above Reno, Nv
    Coil on plug, Just like a modern auto. No spark plug wires on the 1330 motor.
    Lew L
    2014 RTS , Circuit Yellow
    Jun 2018
    Pahrump NV
    Thanks Lew.
    Aug 2007
    Greeneville, TN
    Only the V-Twin, 998 has spark plug wires, 2008-2016.
    Oct 2021
    Maryland
    Man let me teak you, I was riding with the WS Ark Chapter a few weeks ago, and my check engine came on. Nothing seemed out of the ordinary but after some research on how to discover the code I found it was plugs and wires. Cool! Now to the repair. that was a b*tch lol
    However, replaced the plugs and wires with Baja Ron and runs a helluva lot smoother than before. And I have a 2013 Spyder RT manual.
    Now on to my next adventure of figuring out how to replace the ignition because I cannot seem to locate and purchase a master key to program my second key.
