Page 1 of 2 12 LastLast
Results 1 to 25 of 32
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Default Installing Trailer hitch - avoiding obstruction in axle housing?
    Looking to put a trailer hitch on my 2022 F3-L. Problem is there is
    obstruction built in the axle housing of the bike. Does anyone have
    the installation instructions or how do I get those obstacles out of
    the way? Thanks for any help.
    2022 F3 Limited , Monolith Black / Dark
    Jul 2010
    Las Vegas, NV
    ??? Pictures please. I’ve put on many - no obstructions!
    Joe Meyer
    Jun 2013
    Uniontown, Pa
    Here you go and the other side is the same.
    Still looking for a way to remove this obstruction. it's in the rear axle of a 2022 F3-L.
    Thanks for any help
    Jun 2013
    Uniontown, Pa
    Added info
    Jul 2015
    Dorr, michigan
    Nothing to remove, trailer hitch for the bike goes over that. If you look at the pic, there is a bump out in front of the three mounting bolts, that axle nut you show is under that.
    2020 RT Limited , Petrol Blue
    Jun 2013
    Uniontown, Pa
    If you look at that 4th bolt just in front of the 3 you are
    talking about you would see that it goes all the way through.
    Thats the bolt I am having trouble with.
    Jul 2015
    Dorr, michigan
    Yes I know, I have installed several of these, the hitch goes on covering the axle nut, long bolt goes back through and and the small nut goes back on just as the pic shows.
    Jul 2015
    Dorr, michigan
    https://www.youtube.com/watch?v=PbmWoN9Vqws
    Watch this video, it will help.
    Active Member obiwanbill's Avatar
    Apr 2009
    toledo ohio
    I put one on a 2008 GS and a 2020 RT LT.
    #1. the hitch DOES NOT go on in a few minutes, easy peasey like in the you tube videos. Those guys might have pre fitted, practiced a dozen times before turning on the camera. This is TRUE in all YOU TUBE Videos!
    #2. The hitch is in 3 pieces. the 2 brackets cover over those huge axle nuts; fit per instructions with spacers. a nut goes on each end of the 2' rod that runs inside the bike's existing axle. With some models of hitches, the 2' axle rod/bolt is drilled in order to use a cotter pin. my 2008 hitch was 1 piece, not 3. Some genius somewhere decided that all Spyder owners AFTER performing all this grunt work, would like to take it partially off when not towing. WHY?
    #3.A. the same hitch is available from CanAm for hundreds more than anyone else (DUH) B. The same exact hitch kit is avail from Spyder dealers on this site for $250, but if you put bolts to metal (tiny scratches) and it don't fit right, no returns! C. Amazon $180, if it don't work right, free shipping, free returns. D. eBay $140, but ignored my questions about refunds/returns. So I bought Amazon.
    Former Navy LT, Retired Chemical Dependency Therapist, Retired Widower, "Do, or do not, there is no try"... Jedi Master Yoda.
    Proud member of AA, PGR, and a Navy Shellback!
    2020 RT Limited Chrome , matte black trim, Green/gray Charcoal? depends on the lighting
    Jun 2013
    Uniontown, Pa
    Watched that video several times. If you look at the photo I posted you will see
    that it is blocked inside. That long bolt has no way of going through. I need to find
    out if I can remove it. If not I may try to drill it out. Then again the 2022 F3-L may
    not be able to handle a trailer.
    Jul 2015
    Dorr, michigan
    Did this have a trailer hitch on it before?
    I know that on the Show Chrome hitch, it comes with inserts that go into that axle and the small bolt goes through those. Inserts shown in this pic.
    When I take the hitch off to change tires, the inserts stay in the axle, they do not come out with the bolt. Inserts are 3rd and 4th up on the Left side bottom of pic.
    Just a thought.
    Sep 2013
    Houston
    Quote Originally Posted by DriftersWay View Post
    You will need to purchase an axle shaft for a 15 thru 21 F3. The 22s are coming like yours without the hollow axle. It's due to a parts supply issue for BRP that was preventing bikes from being built. Or you can swap yours with someone that has no need for a trailer.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    " Drill it out " ..... Anything is possible - However drilling a hole in 12 " +/- axle isn't something the average DIY'er can do ..... good luck ... Mike
    Apr 2019
    Clinton, MS
    I agree with James. There have been several reports of the new axles not accepting the trailer hitch thru bolt. If you look at the picture closely it looks like the hole is only about 1/4 inch.
    Apr 2016
    Se pa
    Call your Dealer and check on trailer hitch axle bulletin, BRP will replace axle parts and labor. I was just at my dealer this morning about this, & he ordered me a new axle.
    Jul 2015
    Dorr, michigan
    Great information!!
    Thanks for the update and education on that one.
    Jun 2013
    Uniontown, Pa
    Quote Originally Posted by Fatcycledaddy View Post
    Great information!!
    We both got educated my friend.
    Jun 2013
    Uniontown, Pa
    Mike you are right. It is not what I thought. It looked like a brass insert at first.
    I was wrong, there is a 1/4" hole going through the entire length of the axle.
    There is no way I can drill that. I have to see about getting a new one.
    Jun 2013
    Uniontown, Pa
    Quote Originally Posted by Astro-bob View Post
    Thanks for the info. I will be at my dealer first thing in the morning.
    I was wrong there is a 1/4" hole going through the entire length of the axle.
    The WHY it's now different is an issue ..... I made three of my own Hitches .... all the OEM - BRP axle's could accommodate a 5/8 in. threaded ROD ....... the ones I made and I'm very sure everyone else's has the HITCH plates using the AXLE as the Actual support piece in this..... so the plates can be held on with a 1/4 in ROD .... it is not STRESSED at all ..... jmho ... Mike
    Jun 2013
    Uniontown, Pa
    Just got back from my dealer and there was an issue.
    He has my new axle on order, and I may have it on by
    the weekend. Under warranty.
    Well that's interesting ..... glad it's under warranty ..... Mike
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    I asked my dealer about this. She had heard of this issue on RT's but not F3's. She's going to look into it and if she finds anything I'll update here.
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Jun 2014
    Schenevus NY
    My dealer confirmed the issue on F3's as well. She ordered the replacement parts but if supply chain issues prevented BRP from building the bikes with the correct axle I wonder if supply chain issues will prevent them from shipping the replacement parts?
    I'm just glad I still have an older Spyder to ride.
    Trb-- (Roger)
    Jun 2014
    Schenevus NY
    Dealer told me yesterday that the replacement axle's are now backordered until the end of August.
    Trb-- (Roger)
