Results 1 to 23 of 23
    Active Member MNBK's Avatar
    Mar 2017
    Circle Pines, MN
    Default Garmin Zumo XT - how readable; mountable; & lockable are they?
    I have a 2016 F3T and am thinking about a GPS I have read the reviews and other information about the XT. I have a couple of questions:
    Is it really easy to read the screen during sunny days?
    Where have most of the users mounted it?
    Is there a type of lock that can be installed so it can be left on the spyder?
    Thanks for any information you can provide.
    Last edited by Peter Aawen; 07-18-2022 at 09:22 PM. Reason: Expanded Title to briefly ask the question ;-)
    Dave....
    2016 Red/Black F3T w/ Audio
    Bajha Ron Swaybar, BRP driving lights
    F4 Windshield, Ultimate Tallboy Seat
    BRP Passenger Backrest
    Custom Dynamics fender lights
    Tricled Rear Bag lights w/ Flashing Brake Modulator
    Wolo Horn, Lamonster's Bungee Buttons
    Spyderpops Bumper Skid
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Smile
    Quote Originally Posted by MNBK View Post
    I had a 2015 RTL. It is difficult to read in sunlight even with a shade over the top. But, you can bluetooth it to your intercom if you have one and it will speak directions into the intercom. I had it mounted in front between the bars. The mount had a quick release and you could easily take it off and store it in the frunk, back, or side pods and lock things up.
    Oct 2020
    KS
    Yes there are a number of mount options that either lock or release for said storage elsewhere. I would disagree a little on the visibility in daylight. For me in sunlight here in KS I think it is very visible without any kind of shade, best GPS visibility I've had over phones and other GPS units. It does have a brightness adjustment, make sure it is all the way up.
    2021 Spyder RT
    Apr 2019
    Clinton, MS
    Quote Originally Posted by milryder View Post
    Sep 2020
    Middletown, NJ
    The XT has the best screen of all the Garmin Zumos. It is much brighter than prior models. The XT has it's down-sides though. It no longer supports TPMS or VIRB cameras And all data transfers are now via wifi - no USB ports.
    Locking mounts are available but they are costly. Best to remove and carry or lock in a compartment when leaving the bike.
    2020 RT base , Chalk White
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by Baron14y View Post
    Are you sure you are referring to the XT, Baron? We get some verrrrry bright summer days out here and I have never had an issue seeing the screen clearly. On my previous 590, yes it was an issue……on the XT, no.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2016
    Quote Originally Posted by RayBJ View Post
    I certainly don’t find data transfer via wi-fi a down side, Ray (horses for courses). I drive into my garage, which has a wi-fi extender, and if there are any updates the XT performs them before shutting down. For me, that is a huge bonus as I am always up to date. I agree completely with the “pop it out of the cradle and into a saddlebag” option. I can’t see the need for a lock as the XT is sooooooo easy to remove with a single button.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jul 2014
    Mint Hill, NC
    Here is a link to the Kradellock, a very good GPS lock for the XT: [URL="https://robertbeckerdesign.com/gps-locks/zumo-xt/"]/URL]. You just have to be certain your mount can't be snatched. I have one for my 590 and leave it on the bike all the time except overnighting when on tour.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    May 2017
    Mesa, Arid-Zone-A
    I have a Garmin Zumo 595LM and keep the brightness all the way up with no problems in sunlight..... And we DO have a bit of sunlight here in Arizona. I believe the XT is even better. As for a lock, take a look at Zumolock. Less expensive and every bit effective for use daily. I do remove the GPS for motel overnights. Zumolock is a 2 part locking system. One for the GPS and another for ram mounts. Then you can use one of many options for ram mounting your GPS. If you do decide to order a Zumolock, have patience. They are made in and come from the Netherlands. Good product though. Good luck..... Jim
    Semper Fi
    Member Isntthatdandy's Avatar
    Jul 2022
    Kansas
    I’m from Salina, Kansas with lots of bright sunny days. I haven’t had any difficulty seeing the center-mounted screen. It has day, night and automatic modes. You can also adjust the angle of the screen. I quick disconnect mine and put it in the rear case if I leave my Spyder unattended. Hope this helps.
    "The plural of anecdotes is not data." ~M. Dillihunty
    Regards, Jim
    2022 RT Limited , Slingmods Carbon Black
    Oct 2014
    Loudon, TN
    The XT has a very bright screen, much better than earlier models - especially the 595 which was among the worst. And the XT most definitely has a USB port through which you can do updates and file transfers in addition to WiFi. USB works perfect on windows computers but is wonky on Macs (I use a program Commander One with the Mac).
    2014 RTS
    2014 RTS SM6 , Cognac
    Aug 2019
    Stoughton, WI
    My Zumo XT is very legible in bright sunlight. I also spent the $$ on a nice Touratech lock. It was $25 cheaper when I bought it. I have no concerns leaving the GPS in the lock. I also use one of these .. https://www.rammount.com/part/RAM-KNOB3LU on the RAM arm.
    https://touratech-usa.com/store/Tour...Garmin-Zumo-XT
    2022 RT Sea To Sky
    May 2019
    Palm Bay, Florida
    Pete
    I stand corrected. I had a Zumo 590LM.
    Sep 2020
    Middletown, NJ
    As for security of the RAM mounts, a cheap way to discourage a casual thief is to replace the wingnut on the arm with a nyloc nut. Granted, it can be un-bolted with tools but so can the RAM mount bolts if mounted to the bars.
    Aug 2019
    Stoughton, WI
    Cheap insurance .. https://www.ebay.com/itm/20155343582...3ABFBMsPOM-sJg
    2022 RT Sea To Sky
    Mar 2021
    PA
    Another huge plus to the XT, if you have a SXS get the Garmin Tread. It is an XT on steroids. Simply move it from mount to mount!!
    Jan 2015
    southern WI
    In my opinion, excellent in all aspects
    2021 RT Limited
    2016 RTS , Pearl White
    Apr 2021
    Bartlett, TN
    Like the others have said, the XT screen is easily readable in bright light. I rode Sunday in 96 degree weather with the sun blaring down and not once could I not see it. Best screen on a GPS I have ever seen.
    I have it mounted between the bars with the Lamonster riser mount. You do have to glance down a little to see it but it is not bad. THere isn't a good way to mount it above the dash on the newer 2020+ models that I have found.
    I don't worry about a lock because it pops right off the mount with one hand with one button and I just toss it in the rear trunk when I want to leave the bike and not worry about it getting stolen.
    2021 Spyder RT-L Deep Marsalsa Metalic
    Oct 2021
    Wichita, KS
    Quote Originally Posted by canamjhb View Post
    I like that a lot. I've never seen one before. I could design something and 3d print it but for $10 you can't beat this thing.
    Peter Pan has struck again!
    May 2017
    Mesa, Arid-Zone-A
    Quote Originally Posted by FrogmanDave View Post
    That RAM lock is part of what you get when purchasing a Zumolock. I do like not having to worry about my GPS when taking breaks, meal stops, and when the gas station says you need to come inside for a receipt. But it is still easy to remove for overnight motel stays..... Jim
    Semper Fi
    Dec 2015
    Oakley Utah
    Is this a zumolock? https://www.google.com/shopping/prod...375305470,cs:1
    2014 RTL Platinum
    May 2017
    Mesa, Arid-Zone-A
    Nope. The Zumolock is about half that price. I don't know how to attach stuff here but just google Zumolock.com......
    Semper Fi
    Aug 2019
    Stoughton, WI
    These are Zumolocks ... https://www.zumolock.com/index.php/en/purchase/zumolock ... I had a Zumolock prior to to purchasing my Touratech Zumo XT lock. Yes, it is quite a bit pricier, but there is NO comparison in quality and security. The Touratech is like a mini vault.
    2022 RT Sea To Sky
