Results 1 to 9 of 9
    May 2019
    New Mexico
    Default SPYDER F3-S SPECIAL SERIES - pre-purchase questions?
    Good Morning All
    A couple of questions first I'm doing my research on getting a SPYDER F3-S SPECIAL SERIES. So what first what is the break in period for the engine and drive train plus when is the first service. And what are some of the mods I should look into doing Thanks All
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by JohnWJ View Post
    Good Morning All
    READ THE MANUAL, the complete manual from start to finish. Break in time, first and every service intervals.....ALL COVERED.
    Mods required....NONE...until you’ve put a few thousand miles on, and then you’ll know, and appreciate much more.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Second all the above, Read the manual, get a few thousand miles under your belt, then start modding, Spyder is quite capable, right out the box, but there will always be personal thingies, you would want to chane
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Jul 2014
    Mint Hill, NC
    If you don't have access to a hard copy manual download on from this link and drill down to the manual you want.
    https://www.operatorsguides.brp.com/...hp?productId=5
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Bossier LoUiSiAna
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    May 2020
    Walker, LA
    First service 3000 miles. Break-in 600 miles, no hard braking for first 200 miles. As for mods, more lights are always a good thing. First thing I did to my 22 F3 Limited Special was add the Spyclops LED. Very simple added visibility for just over 50 bucks!
    May 2019
    New Mexico
    Thanks
    May 2019
    New Mexico
    Quote Originally Posted by Revjames View Post
    Thanks
    Feb 2020
    CT and ME
    If you're getting a brand new F3-S SS, you will need to plan on getting a windshield as it only comes with a little gauge spoiler. Also get a set of middle pegs - makes it so much easier to mount and dismount the bike. And if you weigh more than 175 pounds I recommend an aftermarket rear shock and spring set up for your weight.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
