Results 1 to 7 of 7
    US new jersey
    Default 2021 RTL - anyone removed upper speaker grills? Help?
    Hello all, has any one removed the upper speaker grills... sending them out to get coated very soon so any help is welcomed...
    Last edited by Peter Aawen; 11-15-2022 at 06:55 PM. Reason: Expanded Title to briefly ask the question ;-)
    Oct 2020
    Vinton, IA
    On my 2020 RTL, I just grab the inside edge with my fingertips and gently pull outward and up at the same time; that should release it the tabs.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    US new jersey
    HI dave the inside edge near the cluster yes....
    Oct 2020
    Vinton, IA
    Yes, there are two tabs/clips on the inside edge that go into the console. Once those are released, the cover will lift and pop out.
    US new jersey
    ill try it again, its in there pretty firm,,,thanks
    Quote Originally Posted by Mosess01 View Post
    Go take a look at the parts Fiche' for that area, sometimes it helps to know Exactly how things go together, to get them apart without breaking anything ..... good luck ..... JMHO ... Mike
    Oct 2021
    Wichita, KS
    You can use a 90 deg. metal pick and pull it up using that. Some sets have a pick with sort of a semi-circle end. That works better.
    Peter Pan has struck again!
