Results 1 to 10 of 10
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    Default Handle bar bolts won't move!!!!! Any ideas??
    Friend installing lamonster power plate….impact wrench doesn’t move a bolt…any ideas ?
    Active Member TCBoone's Avatar
    Dec 2022
    CA
    My approach would be to try a penetrating lubricant and then attempt to remove it with a large breaker bar. Leverage can be your friend. Just my initial idea suppose others may have better recommendations. Stuck bolts can be a challenge sometimes, finding out which part of what you are trying to remove will give first.
    2022 RT Limited Deep Marsala Chrome
    Oct 2015
    Lynden, WA
    Apply heat to the bolt by inserting a soldering iron tip into the socket head of the bolt. It may take a long time but the idea is to soften the loctite deep in the threads.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Harrington, Australia
    Yes, along the lines of what David said above. The BRP yellow loctite, which they do NOT use sparingly, can make bolt removal “difficult”. Heat is your friend.
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2012
    Stetson, Maine
    On mine I used a good quality hex socket and a long breaker bar. I first used a 6 inch extension with hex socket and gave the bolts 4 or 5 good wacks with a 3 lb hammer. It worked.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Aug 2018
    Chicago
    Heat Gun
    2015 f3s
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    mine were so tight that i broke an snap on allen socket.
    an old trick is to try and tighten them, then loosen, that's what worked for me.
    just give em a hard yank, then try and loosen.
    Mar 2021
    Maryland
    You need a small torch like lamonster uses in this video in order to soften the loctite. I used the same torch ( a small bernzomatic butane) for my floorboards and mounting my centermount ram ball on my handlebars with no issues.
    It makes a very small flame that you can point right in the center of the bolt to heat it and not hit anything else .. it works great and costs less than $20.
    2020 F3 SE6
    2020 F3 , Black
    Jan 2018
    North Carolina
    That sounds like the answer
    Jan 2015
    southern WI
    A little heat and a couple good direct whacks with a punch in the center of the bolt head. One of my bolts broke off just below the head of it when I was doing this project. Be careful if just using a long breaker bar, the bolts can break....been there
    2016 RTS , Pearl White
