Results 1 to 15 of 15
    Aug 2012
    Central Ohio
    Default Anyone have any idea where this Mystery Bolt belongs?
    I know this is a long shot but thought I’d try. After hauling the Spyder home to Ohio from Florida I found this Allen head bolt on the floor of the trailer. I cannot find where it came from. It looks to have threadlock on it. Any of you that do your own maintenance have any ideas?
    Last edited by Peter Aawen; 02-27-2023 at 02:22 PM. Reason: Expanded title to briefly ask the question... ;-)
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Kingz View Post
    Which Spyder were you hauling? Model & year!
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
    Aug 2012
    Central Ohio
    Since this is the Spyder RT Touring forum I thought people would know that part. It’s a 2020 Can Am Spyder RT Limited.
    Feb 2020
    Minnesota,USA
    OK! On the 2020RT there are 3 screws on each side that hold the long wing panel on each side. Pull the first 2 panels off each side and look to see if the 3 screws are in place for the #3 panel. They are fastened with a T30 torx screw driver. Hope this helps!
    Bill
    Sorry, now proof read, yours are hex allen wrench head. Looks like they could have come from the Lamonster spyder cuff, 1/4 inch x 20 thread.
    Sorry to send you down those rat holes, maybe it fell out of that Chinese air balloon!
    Jun 2016
    Harrington, Australia
    Kingz, while it is the RT forum, the pre and post ‘20 RT are completely different designs. Plus, when members look at “what’s new”, the forum name is often overlooked. It’s always a good idea to include year and model when asking questions……and even better if you include Year and Model in a signature line at the bottom (Settings (top row of the site), then Edit Signature).
    ……and unfortunately, I don’t recall seeing that bolt on my ‘21 RT.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2016
    Chillicothe, Oh.
    Hmm, thread lock compound and it fell out? Possible I guess, but has the dealership or any one else worked on the machine? My thought is the fastener got dropped and fell down into the black hole of machinery never to be seen again. Whoever dropped it may have replaced it with a new fastener and this one finally jiggled around enough and fell out.
    2015 RT , Black
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    That's a shorter bolt than most. From my experience, that is used on each side of the bike where the side panel meets the wheel well. Visualize it as even with the back of each front fender, approx even with the front of the footboard. the only other spot these short bolts were used is at the side panel upper area approx even and under the middle side edge of the pax seat.
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Member Gekko's Avatar
    May 2019
    Huntington Beach, California, USA
    It might help with the solution if you could provide the thread size and length. Also, is it possible it came from the trailer and not the Spyder?
    Gekko (Larry)
    2019 Spyder RT SE6
    BRP Driver Backrest [219400679]
    Can-Am Spyder RT Magnetic Side View Mirror Mounting System (2010-19) [SM-4018, TAC Designs at SlingMods.com]
    Centramatic Wheel Balancers [MCAS400-410]
    Grab On Grips Grip Covers [FBA_MC402]
    Hopnel Cargo Organizer Nets For Can-Am Spyder RT [41-156]
    Hopnel Four Piece Luggage Set For Can Am Spyder RT [HCTL + HCSL]
    Marinco Power Products Pro Receptacle (in frunk) [12VRCTT.OEM]
    AmazonBasics Dual-Port USB Car Charger Adapter [CLA-2U5480_white]
    RAM 1" Ball Compatible Dash Mount (Black Powder Coated) [RT-RAM3]
    Various RAM mount components, phone mount, camera mount...
    2019 Can-Am Spyder RT / RT Limited Series Repair and Maintenance Manual Master Collection [Best Shop Manuals 180317]
    Show Chrome 41-180 Shorty Antenna
    Feb 2020
    Minnesota,USA
    Post #7, Jetfixer has narrowed it down, he knows these 2020+ RTL's, I would go with his hunch!
    Idaho
    Is it for sure an allen (hex) head? If so, unless BRP made some real changes in bolt usage with the 2020+ models, I don't think it came off the Spyder. The Spyder has almost all torx head bolts and very few allen head screws.
    2014 Copper RTS
    Apr 2019
    Clinton, MS
    And the Loctite is not yellow.
    2019 RTL Phoenix Orange
    Sep 2017
    Durham,Maine
    I know I am riding old iron, but seems to me, somewhere up on or around the dash they used that size screws to hold the bezel on!
    2012 RTL , Pearl
    Jul 2010
    Las Vegas, NV
    If the locktite is Undisturbed, it’s probably an extra, dropped accidentally. Jet fixer is right about where they go, but if those are there, you have an extra. More importantly, screws that small don’t hold structural components. You get an extra! No worries!
    Joe Meyer
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    Allen off a back rest? I just adjusted mine and it has 5mm allen screws.
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    tender plug in, luggage liner/bags, FOBO 2
    Drinks2go cup holder, replaced the seat strut
    Garmin DriveSmart 71 GPS, Garmin BC 30 backup camera.
    White pulley, Pedal Commander
    Laminar Lip- looks fonky but works.
    J&M 2003 CB installed
    Home made belt guard
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
    Member appkrill's Avatar
    Mar 2019
    York, PA
    Easy, only screw that holds the lower black kick panel on a 2019 rtl
