Results 1 to 8 of 8
    Jul 2022
    CA
    Default Where does that Rear Caliper Spacer go, forward or back?
    Hi all, so I changed my rear tire on my 2014 RT. Pulled the Brake Caliper 2 bolts no spacer fell out at this point, later that eve I found a spacer on the floor. Not sure if it was forward or back bolt of the Caliper?? So, wondering the reason for the spacer? Is it for brake alignment or speed sender clearance or ?? Steve
    Last edited by Peter Aawen; 04-13-2023 at 07:38 PM. Reason: Removed Prefix - not 1330 engine specific & expanded title to briefly ask the question... ;-)
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Not sure what you're referring to here. If you pulled the rear wheel, there are spacers between the swingarm and the wheel. There are also shims on the anti-lock brake sensor. They look like small washers, and there could be a few of them. There are no spacers at the calipers, just the two bolts. Without a photo of what you found, it's hard to say.
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Idaho
    I recall having to put a spacer back in when I had the caliper out, but don't recall where it went. I think it might be for aligning the caliper to the disc so try it in both places and see if you can tell which makes the caliper fit better. I think that is what I did. The washer/spacer is not mentioned in the service manual nor in the BRP parts list.
    2014 Copper RTS
    Jul 2010
    Las Vegas, NV
    Look for marks. If one bolt had a spacer, you will see a round printing. I’ve not seen a spacer in any 14 or newer bikes. Joe
    Joe Meyer
    Apr 2019
    Florida Swamp
    Brake calipers are shimmed to make the same amount of space on each side of the caliper.
    Not sure there is a video for Spyder, but you can find videos on the web about shimming calipers. Principal is the same, whether it is a car or a Spyder. Auto parts places should have the shims. All they need to know is the bolt size.
    Take a look at this. If you can get it back where it was, it might equalize the space. If not, try a feeler gauge on it. Might not be in the manual. Shimming is general mechanical stuff.
    https://www.youtube.com/watch?v=dywYE-TAWHs
    https://auto.howstuffworks.com/auto-...ignment%20aid.
    2019 F3-S , Black & Silver
    Aug 2013
    SF Bay Area
    It goes back where it came off and if you didn’t see where it came off then look for any sign where it might have been.
    2021 F3 Ltd , Magna Red
    Oct 2021
    Wichita, KS
    Quote Originally Posted by Cahoots5 View Post
    It goes back where it came off...
    I'm pretty sure based on his first post he does not know where it came off from. That is the point of the whole thread.
    Peter Pan has struck again!
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by Gwolf View Post
    Yes, my ‘16 F3 calliper had 3 shims on it, Gwolf. Fortunately, in the instructions I was following it said to take detailed photos of everything you were taking apart, especially the shims. Like Cahoots, I found one shim on the floor after removing the calliper. If I didn’t have the photos, I would have been using the feeler gauge you mention.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
