Results 26 to 26 of 26
Threaded View
    Active Member USAF's Avatar
    Aug 2022
    NY
    Default Is removing 1330 Water pump simple? How to drain/bleed coolant?
    Hello, I am working on a friends 2021 Spyder RT Limited that is leaking coolant from the water pump housing. Looks to be coming from between the pump housing gasket. I know my way around motorcycles very well but have never removed a water pump on one of these. Before I proceed, I have a few questions.
    Is this just a straightforward job or are there other parts that are going to also come out with the pump.
    Also where is the drainage valve / and what is the bleeding procedure.
    Thanks for your help !
    Last edited by Peter Aawen; 07-04-2023 at 02:41 PM. Reason: Expanded title to briefly ask the question/s... ;-)
