Results 1 to 14 of 14
    Oct 2013
    Wood Village OR
    Default Latest addons to my trailer
    After using the trailer I built last winter and using it this summer to see what improvements I wanted for our ride to Fairbanks and the Artic Circle next summer, I decided to add a water tank and faucet. Since I have a battery bank for My wife's Cpap it was easy to add a 12volt RV pump. The tank eliminates the 5 gallon water jug we have been using and I installed the 7 gallon tank in the rear underneath the bottom. All that's left is to replace the AGM batteries with Lithium to reduce the weight. For those that are going to ask about the weight, its 350 pounds fully loaded. I have about 5,000 miles on it now and we have had zero issues. For faster charging we have a second solar panel we carry in the Leesure Lite that she pulls.
    Last edited by Peter Aawen; 01-03-2024 at 06:30 PM. Reason: Fixed attach display ;-)
    2014 RTL , Black Currant
    Nov 2013
    Central Texas
    Man, that is one sweet setup. Very well thought out. Have fun at the Arctic Circle, and enjoy the ride!
    Mar 2015
    Brockport, NY
    You should be proud of that build! Sounds like you are enjoying some amazing travel adventures.
    2014 RT-S Pearl White
    Active Member Jesster72's Avatar
    Oct 2021
    IL
    Very nice!! I like the set up and a home built at that!
    Question, though. We pull a little tag-a-long for our trips, trailer has been with us through multiple bikes. The Spyder beats the heck out of everything we carry in it - because of the un-sprung hitch. How does your cargo hold up with that beating it takes? (We thought we packed everything soundly, but still wound up losing a bottle of wine on the return trip from PA last year.)
    2022 Sea to Sky
    Faribault, MN
    Kudos to your build ingenuity, love the use of existing RV door/hatches and hardware. Are you travelling with the water tank empty and filling up before stopping for camping or carrying the water tank full while traveling?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Florida Swamp
    I am building a new trailer now, but certainly not anything like your mobile motel and diner. That is a heavy duty project. I am just building a small trailer to haul the wheelchair, and maybe a few bags of livestock feed or groceries. You got some great ideas and put them to good use.
    2019 F3-S , Black & Silver
    Sep 2012
    Stetson, Maine
    What a great build!!!
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Oct 2013
    Wood Village OR
    Quote Originally Posted by Jesster72 View Post
    I will be changing my tongue out on the trailer to the one that I seen on a modified 622.
    Oct 2013
    Wood Village OR
    We run it full all the time if we have a water source nearby .
    Clinton, MS
    Quote Originally Posted by easysuper View Post
    Is that a commercial unit or a homebuilt?
    2019 RTL Phoenix Orange
    Oct 2013
    Wood Village OR
    I believe it was built by a fab shop . It is on a 622 trailer owned by Robert Ferguson ( Two Years on Two Spyders) he also has one on his Leesure Lite pop up trailer.
    Clinton, MS
    Looks like they knew what they were doing. Would love to add something similar to my Time Out Camper. I think there were some past discussion of a similar project here on Spyerlovers a few years back, will have to research. Thanks
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    I applaud your ingenuity and building skills. If you haven't as yet, patent it!
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    SoFlo
    This has been a planned upgrade to our RT622 trailer for a while now. I did spend some time mocking up things, but have yet to build it.
    Decided that for ours to prevent loosening or wear issues of the drilled holes for mounting plates and especially the pivot things would be done slightly different. Mounting plates will be welded and pivot will be done with either a bushing and sleeve, or more likely pivot on ball bearings.
    In my years of rebuilding high performance suspension units, I have a decent stash of mtb shocks. Was considering using the shock in a similar way and location, just had a difficult time accepting how it looked and interferes with stepping over the trailer tongue and accessing the rear trunk on the RTS.
    The other concern could be, if the shock were moved aft, and located into the drop portion of the tongue, there becomes a clearance issue for the RT622 front lid.
    All that said, I am fairly confident when modified, our RT622 trailers tongue will use a low profile design to mount the shock, and more than likely will be an entire new tongue drawbar. Good chance also I may not use a shock, but keep it simpler with easy to replace low cost, elastomers. As reliable as a quality mtb shock is, a failed seal and loosing all damping would make for a very springy trailer setup.
    Just thoughts, there kind of is no true wrong or right answer for this.
