Results 1 to 8 of 8
    Jan 2015
    southern WI
    Default How important is balancing the rear tire?
    I had a car tire mounted by the local tire guy this weekend, and of course he didn't have a way to balance it. There are a half dozen weights on the wheel, it seems to ride fine, but maybe just a bit more wiggle in the bars. Thought about taking those weights off...
    Thoughts?
    2016 RTS , Pearl White
    western Colorado
    Ride on auto formula is what i use in all 3 tires
    Quote Originally Posted by Mazo EMS2 View Post
    Thoughts?
    At my first REAR tire change ( to an Auto ) I went to a Mtc. shop and had it balanced ...... the next one and the 6 after it I didn't..... frankly I couldn't tell the difference ..... Front tires/wheels are different from the REAR for Spyders ..... the rear swing arm is substantial, and the wheel/tire is kept in a fixed position. .... I think Peter agree's .... If you are using a Kenda tire - - all bets are off ..... JMHO ....Mike
    Northern Kalifornia
    I recently had my rear tire replaced and the tech put 28 psi in the tire. For 2 days everything vibrated from the floorboards to the windshield. I dropped the psi to 17 cold and it ran up to 21 hot. All the vibration went away.
    17 to 21 ....this is normal & the PSI's peter and I reco0mmend account for this rise ..... Mike
    Bossier LoUiSiAna
    If was same brand tire as before & tech was skill - may have lined up as previous tire & balance the same. **MAYBE**. Something to do with color dots on edge of tires. Apparently helps when swapping same brand (production process)
    https://www.spyderlovers.com/forums/...ire-yellow-dot
    May 2017
    Mesa, Arid-Zone-A
    If the weights were for your previous tire, I'd remove them. There is zero chance they are doing you any good. Good luck..... Jim
    Semper Fi
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Pop some balance beads in the tire. Easy to do.
    Joe
    2023 F3
