Results 1 to 14 of 14
    Sep 2023
    Harford county Maryland
    Default Anyone installed Mirror turn signals on their RT? '23 S2S
    Has anyone installed mirror turn signals on their Spider RT? I have a new 2023 Sea to Sky that I want to install them on.
    Last edited by Peter Aawen; 09-21-2023 at 06:04 PM. Reason: Expanded title to briefly state the reason for this thread! ;-)
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Danbury Connecticut
    Quote Originally Posted by eddieshep999 View Post
    Excellent video. Pierre does a great job of explaining things.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Jun 2021
    Bossier City, LA
    I have the kit from SpyderPop, and I could not be happier. They look similar to what is pictured above. I also have the fender turn signals.
    --Exco
    2021 RT-L only has a few cosmetic mods
    Sep 2023
    Has anyone installed turn signals on their mirrors for a Spyder RT ?
    I like the idea of being seen more clearly when turning at an intersection. I am also a new rider.
    Last edited by Peter Aawen; 09-22-2023 at 08:34 PM. Reason: Moved Post title into text after merge - many only see Thread titles, and post titles mess with Searching! ;-)
    Nov 2018
    Waynesboro, PA
    I have these on my RTL and like them alot; long horn turn signal lights for 2010 to 2019. https://www.lamonstergarage.com/can-...led-light-kit/
    The OP Post was changed to show year & model of Spyder 2023 S2S.
    Long Horn turn signal lights for 2020 + https://www.lamonstergarage.com/lamo...9-f3-t-f3-ltd/
    Last edited by CopperSpyder; 09-23-2023 at 04:19 PM. Reason: correct info for 2020+
    My Spyder
    2012 RTL , Brown
    May 2014
    Cornish, Maine
    A few years ago I put some stick on arrow ones on our 2013 RT Limited. I either got them at Walmart or on Amazon. Inexpensive and easy to tie into the mirror lighting already there. I lighted them more for me to see if the directional stayed on or shut off! very visible from behind too. Did not take up to much viewing area either
    Feb 2017
    Yes, we installed them on my wife's 2021 Sea to Sky. Not a difficult task and a tremendous improvement.
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
    Danbury Connecticut
    Quote Originally Posted by MCole View Post
    Quote Originally Posted by CopperSpyder View Post
    I have these on my RTL and like them alot. https://www.lamonstergarage.com/can-...led-light-kit/
    These are mine from Lamonster.
    I still don't know why the North American RTs don't have the mirror mounted turn signals, that are readily available elsewhere.
    https://www.spyderlovers.com/forums/...=1#post1683310
    IBA #47122
    Sep 2023
    What fuse block and harness should I use for mirror turn signal addition ? Thanks.
    Sep 2021
    Fredericksburg, VA
    I use this Fuse block. https://www.lamonstergarage.com/elec...ent-lamonster/
    It was an easy addition to my bike...When adding stuff to the bike I prefer to isolate as much as possible... I'm not a fan of splicing into the bikes factory electrical wires.. I put it under my rear seat. I have a F3T and there is more room under the seat then there is on a RT
    It says its for a 2020+RT but it also works on a F3T and F3L
    RiderDuke
    My Ride
    2021 Glacial Blue Metallic F3-T
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    I just ordered a set .
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
    Oct 2010
    These are available from Slingmods
    https://youtu.be/hDZQLxofZWA?si=HFiLETkCOEamVdB3
    Eddie Sheppard
    Poole Dorset UK
    indpls in
    those are sweet for sure going on my next new rtl
