Results 1 to 5 of 5
    Active Member Old Prof's Avatar
    Sep 2015
    Columbus, Ohio
    Default '16 RTS Rear Trunk Lid STUCK in closed position. Solution???
    OK...new thread here. I've found several threads here focusing on this problem. It seems the advice offered thus far works on SOME RTs.
    For some reason the '16 is different?? I know this is undoubtedly the most creative, problem-solving group of Ryders on the planet. So...
    2016 RTS SE6
    '64 Honda CA95 "Dream"
    Durham,Maine
    I think if you get down underneath that lever you may be able to see where that cable is attached to the handle and hook on to it and give it a push with a screwdriver. Good luck
    2012 RTL , Pearl
    Jul 2010
    Las Vegas, NV
    Did you fix it? Call if you need to. Joe
    Joe Meyer
    Sep 2015
    Columbus, Ohio
    Sadly, the cable was broken...so....out came the hammers and physically removed the old latch & replaced with a new one. The solution suggested using screwdriver inserted in left latch did NOT have any effect on my '16. Again thanks to all for the suggestions and kind thoughts....yes, it was a PITA, but all is well now.
    2016 RTS SE6
    Northern Kalifornia
    Yes, call Joe. He showed me how to access mine. It's not difficult.
