Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 166
  1. #76
    Active Member Johndeeredoo's Avatar
    Aug 2018
    South haven michigan
    Quote Originally Posted by WRCLVR View Post
    Another update..this re the short reach handlebars for the 2024 RT Sea to Sky. BRP has the short reach position A # 219400909 as fitting the 2024 S2S. My dealer confirmed that today and let me know they do have one in stock. I told them to put it on the bike tomorrow as it is in the final stages of checking out for the screen issue......
    Per BRP website those 219400909 are for people 5' tall and short arms. It ALSO says they are part of the UFIT system...Link: https://can-am-shop.brp.com/on-road/...andlebars.html
    Update on my 2023 Sea to Sky with the 6 month old Haijliu battery...I replaced it with : 12V 21AH 350CCA AGM 12/0 CYLA24HLBSXTA from Batteries Plus. 13.1
    Despite being on the maintainer the old battery was not cranking the bike over very fast. The new battery read 13.1 volts after BP added the acid and charged it overnight and again 13.1 volts just before I installed it. The 6 month old Haijliu battery read 12.4. The new battery turns the bike over much faster.
    As far as I am concerned (AFAIAC) that battery or a Yuasa is the ticket. Dont accept the Haijlui on your new powersports machine.....
    Thank you for your post, lots of good information here.
    I have a 2024 spyder RT too, as for my battery, I still have the Haijli battery, and so far its starting the spyder, but thinking of replacing it if problems come up. I had to replace my 2018 RT battery when it just died unexpectedly on a ride.
    AS for the reverse problem, I had the same thing on my 2018 RT, sometimes would not go into reverse, it turned out to be in the reverse control button on the handle bar, I fixed it before taking it to the dealer, I have read on the forum where other people had the same problem and waited days to months for the dealer to replace the switch.
    But that's not the problem you have, but close.
    As for the low reach handle bar, I noticed I had to reach further on my 2024 compared to my 2018, and both have a back rest.
    I added 1.5" to the 2024 back rest to bring it up a little higher, so it's pressing higher on my back.
    I also added 1" long round blocks under the handle bar holder to raise it up and back, its better, and the extra benefit is I can see what's behind me in my mirrors instead of seeing my hands. I see this is a option from the third party resellers, and may try 2" risers to see if that helps, I know it will help to see what's behind me.
  2. #77
    Apr 2012
    Greenville, SC
    My 2024 has I think that same no-name battery. I looked at it to see what the brand was a while back. It does not spin the motor over very enthusiastically so I may just proactively replace mine with a 350 CCA battery too and not risk it. The Batteries Plus one looks good, is 350 CCA and has great reviews and is in stock locally so I may pick one up today even
  3. #78
    Jun 2016
    indpls in
    I just ordered two Yuasa batteries from Amazon for wife and my new '24s that have less than 5 miles on them.
  4. #79
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Quote Originally Posted by Johndeeredoo View Post
    Appreciate the info. Yes i adjusted the S2S drivers back rest too as it was angled way too far forward. Now it sits nice and flat on my back..BUT.. farther back....Those blocks you described..Which vendor did you use? Lamonster?
    If the new bars need something I will look at adding the spacers or riser block. Good to know that the mirrors will provide a better angle then.
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
    2023 RT Sea to Sky Shadow Green (guess what? NO errors at all in 9 months of owning!) Such a sweet S2S :-)
  5. #80
    Active Member JB62's Avatar
    Feb 2024
    Dover Delaware
    Quote Originally Posted by jfischer View Post
    Depending on your state, you might be able to lemon law it based on number of trips into dealer and/or amount of time it's been out of service, or will be out of service potentially. IANAL, but that's what I'd be looking into were it me. Some states do not cover motorcycles under their lemon laws, but Delaware seems to not have that exclusion based on a very quick Google search
    Good luck...
    The lemon law doesn't apply to recreational vehicles in Delaware. So I will be waiting until its fixed
  6. #81
    Nov 2022
    Georgia USA
    In that case, we hope it gets fixed right, quickly and you get it back and start the miles of smiles...Hang in there buddy, there are several of us Spyder Lovers members in the same boat with codes, screen issues, and ACP not there yet....
  7. #82
    Apr 2012
    Greenville, SC
    I took advantage of the 15% sale last week at Batteries Plus to get their AGM battery. Put it on my NOCO charger overnight then installed it. So far so good, it does seem to spin the engine more enthusiastically than the stock battery did. Might be overkill but for $100 figured I'd rather get that known substandard battery out of there. I did add the star lock washers too just for insurance.
  8. #83
    Nov 2022
    Georgia USA
    I also posted this in the other thread by maplehawk... my dealer finally got the ACP flash in from BRP and installed it to my new 2024 S2S!!! They indicated it took about 1 hour as they then had to check everything out and erase those sticky codes everyone seems to have had.
    So go bug your dealers, BRP released it to mine so they should/oughta do the same for you.
    YAY!
  9. #84
    Nov 2018
    San Antonio, TX
    Thanks for the info!!! Just called my dealer and left a message for appointment to update ACP.
  10. #85
    Feb 2024
    Dover Delaware
    Quote Originally Posted by BlueSpy View Post
    The Apple CarPlay update was out for less than a day and they removed it, so you are wasting your time going to the dealer. My Spyder was flagged to receive it in their system, then a few hours later it was no longer there. So as of now, Apple CarPlay is not out.
  11. #86
    Mar 2024
    Ontario
    Quote Originally Posted by JB62 View Post
    I know they removed the WiFi download. Did they take the download away from the dealers as well?
    2021 Ryker 900 (sold)
    2024 S2S
  12. #87
    Feb 2024
    Dover Delaware
    Quote Originally Posted by Riplin View Post
    Yes they did.
  13. #88
    Nov 2018
    San Antonio, TX
    Hmm… just got a voicemail from my Service Manager to bring it to them on Tuesday at 10am; but I will call them again, to ensure they have it before I go there, so it’s not a “wasted” trip. It takes about 45 minutes to get there… Service manager says that they are always on top of the latest updates on their BUDs system…. That is in accordance with the Shop Manager. But I did notice in the voicemail that they “should” have it, and as ya’ll know, “should” is a pivotal word in sentences!
  14. #89
    Feb 2024
    Dover Delaware
    Should have it, exactly. Bet they don't, Can-Am has been a huge let down to me. Clown show!
  15. #90
    Nov 2018
    San Antonio, TX
    Just watched Shawn Smoaks video from yesterday and he was using it on a 2024 Spyder. Hmm, continuing saga, we’ll see. I texted the Service Manager and asked him/Shop Manager to “double-check” to see if they have ACP on their BUDS. Won’t know answer till Monday about 10am, will call them first before I go up there.
  16. #91
    Nov 2022
    Georgia USA
    Well, I'm waiting on the Android Auto update and release as I'm a 15-year Samsung user and refuse to do what Apple wants me to do. So I don't care about ACP EXCEPT that the update and previous flash was to fix all the screen errors and get rid of persistent codes... which it seems to have done. Well, that is today of course. patience, PADAWANS, the Dark Side may be waiting. LOL
    But I can sympathize with all you guys that are Apple users and can state from my perspective, this ACP/AA is a terrible blot on Can Am/BRP's reputation. What better way to help destroy your reputation and fan/user base than to promise and show something at product release, delay it 7 months, and then yank the update release after 1/2 a day after it clearly has bugs! Which they did not seem test BEFORE releasing....
    What is worse... no mea culpa, no chit chat, no apologies... My 2 cents.
  17. #92
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    I got a call yesterday from a lady at BRP wanting to know how I liked the new Apple Car Play. She was totally surprised when I told her that it was not working.
  18. #93
    Nov 2022
    Georgia USA
    One hand behind their back not knowing what the other is doing. We should bombard BRP and let them know this is BS and to get the real fixes in. Meanwhile BRP should tell all their marketing/PR and customer service reps, ACP is not ready as the release has bugs and was pulled back in less than a day......whip lashes to the IT folks for shoving bad code out the door before testing it, but 1 brownie point for yanking it back before it screwed up many people's bikes....
    BTW, when I contacted BRP several weeks ago with all the issues, yes, I got a case number and a senior tech contacted my dealer after 4 days, BUT the BRP rep refused to get me a link to the BRP satisfaction survey, did not even say someone would call me back...
    To me this says we don't care and don't want to hear about good comments or tough issues, just bugger off...
    I got a better idea, someone get the email addresses of the CEO/product managers of the BRP Can Am division and spread it around, then we can fill their mailboxes up...
  19. #94
    Nov 2022
    Georgia USA
    Here is the link to the BRP Q4 press release...I guess they think the 2024 on road vehicles was a "successful" release..
    https://news.brp.com/static-files/64...9-165fbe4abfc5
    BTW that report is indicating a large drop in sales in Q4 .. Anticipating even more (35% drop ) as inventory at the dealers isnt moving well....
  20. #95
    Active Member Maplehawk's Avatar
    Dec 2023
    Saint Cloud, FL
    Spoke to my Dealer yesterday and was told by the Service Manager that there is no current ACP update either for the Customer (WiFi) or the Dealership BUDS.
    2024 RT Limited, Petrol Metalic Sold, replaced with Goldwing
    Baja Ron Sway Bar
    TricLED Front Fender Reflectors with Sequential LED Turn Signals & Running Lights
    Show Chrome LED Trunk Lights with Run, Brake & Sequential Turn Signals
    Mo-Door Garage Door Opener
    Fobo Electronic Tire Pressure Monitoring System
    Show Chrome Heavy-Duty Replacement Rear Trunk Lid Lift Support Strut / Shock
    Show Chrome Trunk Mounted Luggage Rack
    SpyderExtras Billet Aluminum Handlebar Riser Kit
  21. #96
    Nov 2018
    San Antonio, TX
    Same here, not available via BUDS at dealership: location: San Antonio, TX
  22. #97
    Feb 2024
    Dover Delaware
    After a long fight with BRP to fix my Spyder, my dealership and BRP are going to replace my Spyder.
    The dealership service department couldn’t get my Spyder to communicate with buds system.
    If you recall it would sometimes not go into reverse. BRP wanted them to vent the HCM but couldn’t get to connect to buds.
    After about 8 calls to Can-am customer service they sent me a email telling me that they were working on my case and did nothing. Finally, they sent me this email.
    BRP had no idea why my unit would not connect to buds. It turns out that a small batch of 2024 Spiders will not hook up to buds to trouble shoot faults.
    I forwarded the email to my dealer, and they contacted BRP regional and elevated my issues so now they are going to replace my Spyder.
    Without the dealerships help I would have been unable to get it resolved. My service Department and the dealership have been great.
  23. #98
    Feb 2020
    Minnesota,USA
    I forwarded the email to my dealer and they contacted BRP regional and elevated my issues so now they are going to replace my Spyder.
    You definitely got their attention, now we all have to give them a chance to fix it!
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
  24. #99
    Feb 2024
    Dover Delaware
    Quote Originally Posted by Knizar View Post
    BRP customer service thinks we are going to roll over and play dead. That we have no choice but to do as they say.
    But they start to get concerned went you start elevating your problem up the food chain. Moral of the story is keep the heat on them.
    Squeaky wheel gets the oil. My Spyder has been at the dealership for 2 months. I only had it home a week
    Last edited by Peter Aawen; 04-12-2024 at 07:43 PM. Reason: Fixed quote display ;-)
  25. #100
    Nov 2022
    Georgia USA
    Sounds like your dealer was very helpful and BRP actually listened due to the constant heat. I am concerned that "some" spyders won't communicate with BUDS2...I'm starting to wonder if that might have been part of the issues where the codes could not be erased by many owners, and maybe the issue of the screens all along? (remember some people got their bike re-flashed based on vin#'s?)
    JB62... please keep your bike's VIN. If that one gets put back into the wild... some poor sucker is not gonna know the history of it...
