Results 1 to 17 of 17
    Sep 2023
    Missouri
    Default What AirHawk model/size for 2020 RTL ?
    What Airhawk model/size are folks using on their 2020 RTL seat?
    I assume it just sits there - been a decade or so since I had one LOL.
    I'm assuming the AirHawk Cruiser R Large but just wanted to get any feedback from anyone already using one.
    Thanks.
    2020 RT , Asphalt Grey Metallic
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    kdog, I have a large airhawk and and smaller like this: https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
    AIRHAWK 11" x 11" Dual Sport Motorcycle Seat Cushion - Lightweight Portable Inflatable Multi-Cell Air Pad with Breathable Spacer Mesh Cover & Non-Skid Bottom
    I like the smaller a bit better than the large. Good luck.
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
    Bossier LoUiSiAna
    Jun 2018
    Pahrump NV
    That's a good one. Mine ain't quite that big. I did change the wording to reflect a large airhawk and a smaller airhawk.
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by kdog View Post
    Thanks.
    Large cruiser R
    2015 RT , Black
    Sebring, FL
    Seems to be several large cruiser R's, can you be more specific, maybe a link to one you're using. Thanks.
    Sep 2023
    Missouri
    Quote Originally Posted by Bangorbob View Post
    That's interesting. I'm leaning towards the Cruiser Large R (I'm on the bigger side) but I do remember having it on other bikes and it seemed to push against the sides of my legs a bit. I'll think about that 11x11 as well - thanks Bangorbob.
    2020 RTL - switched over from 2014 Harley Tri-Glide
    CMA Chapter 1018 President, Harrisonville MO
    https://www.youtube.com/@rideblessed
    Sep 2016
    Chillicothe, Oh.
    2015 RT , Black
    Jun 2018
    Pahrump NV
    Sir, the larger size felt that it moved my inner thighs out a little. A little uncomfortable at times. I had the smaller left over from my 2 wheeler. Works out much better.
    Sebring, FL
    Good point Bob, I do believe the smaller size would work better unless one has the larger behind.
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    I have an Air Hawk 2 Cruiser Medium - 14"x 14", that I bought to use on my '21 RTL. Seemed to be the right size, but we only used it twice before getting an ultimate seat.
    Last edited by Peter Aawen; 02-21-2024 at 06:21 PM. Reason: Need to put Ads in the For Sale by Owner sub-forum... ;-)
    2021 RT Limited in Marsala Red & chrome (9/20)
    2006 Yamaha Royal Star Venture - Black Cherry
    2003 Suzuki Volusia - Black w/ Gold
    1973 Honda CL350 - Hawaiian Blue
    2021 Limited , MArsala Red & Chrome
    May 2021
    Camano Island, WA
    Airhawk - R-REVB Cruiser R Large was a perfect fit on the 2020 RT
    Sep 2023
    Missouri
    That's a good point Bangorbob - thank you. Much to consider!
    Sep 2020
    Middletown, NJ
    You can also look for the Wildass branded cushion of the same size as the Cruiser-R. Just as reliable as the Airhawk I had before the valve stem base couldn't be patched. I've had the Wildass for about 5 years now.
    2020 RT base , Chalk White
    Oct 2020
    Vinton, IA
    I bought a smaller size, don't remember if it was a med or a small (mine is about 12" x 12"). I did so because the bolsters on either side of the OEM seat press against my sciatic nerve(s); a smaller Airhawk eases that pressure. Also, the shorter version, along with the little extra height, means that I don't spend so much time sittin' on my junk (sorry to all the ladies out there)!
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Sep 2023
    Missouri
    Turns out I have a friend with a AirHawk Large Cruiser R that didn't want it for his Harley, so I did a 3-hour test ride with it. Feels good so buying it used!
    Jun 2018
    Pahrump NV
    Kday, I have a large and small. It depends on how things feel as to which one I use. I also have wool seat cover.
