Ozzie Ozzie Ozzie
Originally Posted by Highway
Hello all. We fixed the codes, now I need to clear the engine light on my 2015 RSS, can anyone walk me thru it?
I can find the hours....
Thanks.
It's somewhat dependent upon what those codes actually were, but if you've resolved the issues that caused the codes, there's a very good chance that just riding the bike a little will clear the Check Engine light.
That Check Engine light does have some specific things that it warns you about; but it's also used as a bit of a 'catch-all' warning when the computers can't exactly specify what's wrong or there's no specific code for whatever it is, so it might be important, or maybe not?!
So tell us, what were the codes you got, and how did you fix them? And now, what's happening that's giving you the Check Engine light? Have you ridden it some, or is it still just there from before whenever you start the engine?
The more you can tell us about what's happened/is going on now, the more likely we can help!
