Results 1 to 5 of 5
    Feb 2023
    Maine
    Default Does anyone use their Spyder 12v Dock for plugging in heated gear?
    If no problems, let me know. I have 2022 RT L with the dock station installed & use the USB side for my phone etc... Thought it might be easier than wiring heated gear direct from the Battery.
    Last edited by Peter Aawen; 02-28-2024 at 11:39 PM. Reason: Expanded title to briefly ask the question... ;-)
    Jul 2023
    Chesterfield SC
    I am not a mechanic but my first reaction would be NO!!!
    2011 Can AM RT-S SE5 Red
    Vermont
    I use a Dual Power Port( USB & 12 Volt) for my heated gear, and my battery tender.
    It is plugged/wired directly to my battery.
    Hope this helps.
    I also added picture to" My Album" of the Dual Power Port.
    I also use the Dual Remote Control Heat Troller( by Warm & Safe) on my and on my snowmobile.
    The Dual Remote Control Heat troller is water proof, and can be left on the bike in the rain, Sealed with tactile on/off w/ 300 degree rotation from 3% to full on!
    Handles 15 amps @ 13 Volt with internal reset for overload & shorts + works from 7 volts to 24 volts.
    Deanna
    Last edited by Deanna777; 02-29-2024 at 04:39 PM. Reason: Added a picture to post @ 7:38PM on 2/28/2024
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Sep 2020
    Middletown, NJ
    Best setup is a direct to battery, fused wire with SAE connector and coax adapter. Can also be used to trickle charge. A more elegant solution is to use a relay controlled by the GPS (key-on) lead behind the right side panel but that prevents using the same wire for trickle charging.
    2020 RT base , Chalk White
    Active Member DickB's Avatar
    Jun 2021
    FL
    How many amps (or watts) is your heated gear?
Tags for this Thread
