Results 1 to 16 of 16
    Default Here's a Rear tire Bargin!
    Because of all the recent POLLS and conversations about TIRES .... I just checked the Tire Rack's website and discovered that the RIKEN Raptor in 215/60-15 is NOW selling for $ 50.00 less than than either the Quatrac or Altimax RT45 ..... .... That's a serious discount .... I still LOVE my Riken after 8000 mi. ..... Mike
    Sep 2016
    Chillicothe, Oh.
    Thanks for the tip.
    2015 RT , Black
    Oct 2020
    Arizona
    The RIKEN weighs 4 pounds more that the General Altimax RT45:
    SELECTED SIZE
    Size:
    215/60R15
    Service Description:
    94H Service Description
    Load Range:
    SL Load Range
    UTQG:
    520 A A UTQG
    Max. Load:
    1,477 lbs
    Max. Inflation Pressure:
    44 psi
    Tread Depth:
    10.5/32"
    Tire Weight:
    24 lbs
    Rim Width Range:
    6-7.5"
    Meas. Rim Width:
    6.5"
    Sect. Width:
    8.7"
    Tread Width:
    6.8"
    Overall Diam.:
    25.2"
    Revs. Per Mile:
    827
    Country of Origin*:
    ID
    General
    SELECTED SIZE
    Size:
    215/60R15
    94T Service Description
    Load Range:
    SL Load Range
    UTQG:
    600 A B UTQG
    Max. Load:
    1,477 lbs
    44 psi
    Tread Depth:
    11/32"
    Tire Weight:
    20 lbs
    Rim Width Range:
    6-7.5"
    Meas. Rim Width:
    6.5"
    Sect. Width:
    8.7"
    Tread Width:
    6.8"
    Overall Diam.:
    25.2"
    Revs. Per Mile:
    826
    Country of Origin*:
    RO
    Quote Originally Posted by Snoking1127 View Post
    SELECTED SIZE
    Size:
    215/60R15
    Load Range:
    SL Load Range
    UTQG:
    520 A A UTQG
    Max. Load:
    1,477 lbs
    44 psi
    Tread Depth:
    10.5/32"
    Tire Weight:
    24 lbs
    Rim Width Range:
    6-7.5"
    Meas. Rim Width:
    6.5"
    Sect. Width:
    8.7"
    Tread Width:
    6.8"
    Overall Diam.:
    25.2"
    Revs. Per Mile:
    827
    Country of Origin*:
    ID
    General
    SELECTED SIZE
    Size:
    215/60R15
    Load Range:
    SL Load Range
    UTQG:
    600 A B UTQG
    Max. Load:
    1,477 lbs
    44 psi
    Tread Depth:
    11/32"
    Tire Weight:
    20 lbs
    Rim Width Range:
    6-7.5"
    Meas. Rim Width:
    6.5"
    Sect. Width:
    8.7"
    Tread Width:
    6.8"
    Overall Diam.:
    25.2"
    Revs. Per Mile:
    826
    Country of Origin*:
    RO
    Yes it does, but doesn't really effect traction ..... and it's been tested using a Spyder RT ... for those that think that matters .... Mike
    Sep 2016
    Chillicothe, Oh.
    I don't think four pounds is going to matter on a machine like this unless you drag it up a flight of stairs every night.
    2015 RT , Black
    Oct 2020
    Arizona
    I was not thinking the 4 pounds more were a problem. Thread depth is almost the same, so the extra weight must be in the carcass, that is "built a bit stronger"!
    No problem ... I was just passing along info ( from my point of understanding ) ..... Mike
    Mar 2013
    Interesting that both of these have a UTOG (tread hardness)rating of over 500 were as the Vredestein Quatrac has a rating of 400.
    I will stick with the Vredestein Quatrac as the softer compound provides better traction, and I still get 30,000 miles on the rear.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Quote Originally Posted by PW2013STL View Post
    The difference between 400 & 500 is not really significant...... the " UTOG " numbers can be mis-leading .... I have seen many tires with LOWER UTOG numbers that don't have the Wet & Dry traction of the Raptor or Vredestein's ...... Mike
    Feb 2012
    Spring City,Utah
    I was looking at Country of Origin. What is ID and RO?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jul 2023
    Chesterfield SC
    I am glad you asked this question. I was wondering myself but thought I would probably look stupid if I asked. Always better to look stupid in a group.
    2011 Can AM RT-S SE5 Red
    ID & RO ?????? - I have the Q-5's and they were made in the Netherlands ..... The country of origin should be on all tires .....Mike
    Feb 2012
    Spring City,Utah
    It's alright Leaping 1. 77 years of a mis spent youth have not done anything to improve the stupid look on my face anyway. Mike, the final entry in the Spec column for both tires.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Dec 2013
    Quote Originally Posted by Leaping1 View Post
    ID = Indonesia
    RO = Romania
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Feb 2012
    Spring City,Utah
    Thank you.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Jul 2023
    Chesterfield SC
    Being 77 myself I understand exactly what you are saying. One thing I like about getting older is that I worry less about what others think of me and my macho image means nothing.
    Leon
