Results 1 to 12 of 12
    Active Member Maplehawk's Avatar
    Dec 2023
    Saint Cloud, FL
    Post Has anyone with a 2024 Spyder RTL installed HeliBars?
    Anyone with a 2024 Spyder RTL installed HeliBars
    Last edited by Peter Aawen; 04-14-2024 at 02:45 PM. Reason: Expanded title to briefly ask the question... ;-)
    2024 RT Limited, Petrol Metalic Sold, replaced with Goldwing
    Baja Ron Sway Bar
    TricLED Front Fender Reflectors with Sequential LED Turn Signals & Running Lights
    Show Chrome LED Trunk Lights with Run, Brake & Sequential Turn Signals
    Mo-Door Garage Door Opener
    Fobo Electronic Tire Pressure Monitoring System
    Show Chrome Heavy-Duty Replacement Rear Trunk Lid Lift Support Strut / Shock
    Show Chrome Trunk Mounted Luggage Rack
    SpyderExtras Billet Aluminum Handlebar Riser Kit
    Member TimKW's Avatar
    Mar 2022
    Colorado
    I added Helibars to my '22. Easy install and a vast improvement over stock!!
    2022 RTL HyperSilver
    2018 Honda Goldwing Tour White
    2022 RTL , Hyper Silver
    indpls in
    you need to make sure they have updated due to the change of controls.
    Feb 2021
    Indiana
    I emailed the Helibar corporate office & they said they will have an adaptor for their bars in a few weeks.
    Dec 2023
    Saint Cloud, FL
    Quote Originally Posted by Cirhere View Post
    Adaptor for what? 2024 stock handle bars are the same as 2023 handle bars, so the Helibar should fit the same.
    Edited: I apologize and stand corrected. The bars are not the same and your statement is accurate, thanks for pointing that out
    Last edited by Maplehawk; 04-15-2024 at 10:07 AM. Reason: New information verified
    Baja Ron Sway Bar
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    I didn't install Helibars did add a 2 inch riser to the stock bars, works great for me.
    indpls in
    When changing handlebars, there are two screws holding the left grip on. Don't ask how I know this; now I need a new left side heated grip!
    Active Member PJveetwin's Avatar
    Oct 2022
    Peoples Republic of Calif. Upper Mojave Desert
    I considered a Helibars, but for the expense , I decided to try the 2" riser first. It solved my reaching issues. Since the instal, I have over 5K miles. Very happy
    2021 RT LT
    Dec 2023
    Saint Cloud, FL
    Quote Originally Posted by PJveetwin View Post
    Already have the 2" riser. Problem is not with the reach/Height adjustment, more to do with the lateral wrist angle
    Baja Ron Sway Bar
    Jan 2024
    Texas
    Perhaps a dumb question... but does this help with short folks, or tall folks?
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    May 2021
    Camano Island, WA
    Quote Originally Posted by Maplehawk View Post
    We have them on our 2020 RT's. The Heli bars made a huge difference, having the ability to fine tune the wrist angle made long rides possible for us.
    Quote Originally Posted by Allen42 View Post
    Definitely NOT a dumb question, because you asked it, instead of just stewing over it without asking, which would've made it much closer to being a dumb question...
    But I hafta ask, which 'this' are you asking about, the Heli-bars, which allow for a wide range of adjustments in height, reach, and hand-grip angle; or the Risers that were mentioned in the couple of posts just before yours??
    Risers tend to improve the reach &/or height of the grips for different riders; with some types ('dog-bone risers' is one name for these) often capable of being angled back or forward to shorten or lengthen the rider's reach to grab the handlebars, potentially lessening back, arm, &/or shoulder strain on the rider; or if they are just 'block' types, they add space below the handlebars when they're in the mount, making them higher & potentially lessening back, arm, &/or shoulder strain on the rider.
    Heli-bars allow you to adjust ALL the bar angles including grip/end; height; & wrist/forearm angles, as well as moving them forwards & backwards, improving reach; while Risers only lift or extend the base that the bars are mounted on upwards, forwards, or backwards, depending upon the type of Riser you select, thereby allowing adjustment in SOME of the bar angles, but not the angles of the grips on the end of the bars which allow changes to wrist & some forearm angles, which Heli-bars CAN adjust for!
    And as such, both Heli-bars AND Risers allow for handlebar adjustments that can suit either Short Folks, OR Tall Folks, depending upon which &/or which style/size of Risers you choose. Heli-bars do it all, and cost accordingly; Risers do some, or maybe just one - height, & generally cost accordingly.
    Help any??
