Results 1 to 7 of 7
    Active Member JB62's Avatar
    Feb 2024
    Dover Delaware
    Default Anyone remove the rear fender extension on 20+ Spyder?
    Have any of you removed the rear fender mud flap extension? Is it required to remove the rear wheel for tire changes.
    I like to see some tire without having to lay on the ground.
    Sort of like a fender delete. Is it a pain in the butt to remove. Thanks for any input.
    Dunno what year all these earlier threads might be about, but the F3's haven't changed all that much, have they?? So maybe it'll help to check out the thread below, noting the pic in Lamonster's post in particular:
    https://www.spyderlovers.com/forums/...=fender+delete
    Badmotorf1nger also asked about them here:
    He didn't get too much response, probably for the reason he gave in his opening post. But there are a couple of other threads too, altho they were posted a fair bit earlier than 2020; but apart from the T's & Ltd's, have the F3's really changed all that much?!
    https://www.spyderlovers.com/forums/...-fender-delete
    Even if you might not get exactly the answer you're after; or even an answer to your specific question; it does always pay to do a bit of Searching first.
    Feb 2024
    Dover Delaware
    Thank you Peter
    Jan 2019
    Western PA
    https://www.spyderlovers.com/forums/...-rear-mud-flap
    If you’re asking about a 2020+ RT, this may be the thread you’re looking for.
    2022 RT-L , Silver
    Feb 2024
    Dover Delaware
    Quote Originally Posted by JSRT View Post
    Thanks that is what I was looking for
    May 2021
    Camano Island, WA
    Quote Originally Posted by JB62 View Post
    Hello, I had posted in the other thread, "I like the looks after the mod" but as others have stated, it's gonna get messy. We both ride solo so I didn't think it would be an issue, it really is. If you ride in the rain, or after it has rained and the roads are still wet, you'll have a lot of extra cleaning on the rear end of the RT, your jacket and helmet. I would not have cut the bottom portion of my fender off if it not been misshapen, probably during shipping. Now I'm going to try and add an extension on to the fender, or I may end up purchasing replacements.
    Last edited by Peter Aawen; 04-23-2024 at 09:06 PM. Reason: Put the Quote before reply, just like a conversation. ;-)
    Feb 2024
    Dover Delaware
