Results 1 to 5 of 5
    Mar 2024
    Georgia
    Default What's the difference between Accessory Power & Power Expansion Harnesses?
    Can someone tell me the difference between an Accessory Power Harness and a Power Expansion Harness? If I have one, do I need the other?
    Last edited by Peter Aawen; 04-16-2024 at 07:34 PM. Reason: Expanded title to briefly ask the question... ;-)
    Quote Originally Posted by DetroitBreeze View Post
    What Spyder and year are we talking about?????? .................Mike
    https://www.spyderlovers.com/forums/...-your-Sig-Line!
    Mar 2024
    Georgia
    2023 RT Limited.
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    I believe accessory power comes on only when the key is turned on. I connected a voltmeter up to the accessory connector wire on the side of my 2020 rtl.
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
    Northern Kalifornia
    Below are two locations to view each type of harness. Keep in mind they all are 12v. Some work with the key on only and some work with the key on or off, depending on your desired use.
    https://www.google.com/search?q=Powe...hrome&ie=UTF-8
    https://www.google.com/search?q=Acce...hrome&ie=UTF-8
