Results 1 to 12 of 12
    Member f110tech's Avatar
    May 2024
    Massachusetts
    Default What is your opinion on the plastic oil pump gears?
    I just bought a 2015 RTL with 45,000mi on it. It looks and runs like new, but when I was digging around with the search feature here, and on a few other sites, people talked about some failures due to the plastic oil pump gears.
    Previously, people have had them fail at around 35k or less.
    Should I crack open the cover and replace them as preventive maintenance at this point? How many miles does everyone have on theirs?
    Current Ride: 2015 RT Limited
    Previous Rides
    2015 Kawasaki Vulcan Nomad 1600
    2006 Kawasaki Mean Streak 1600
    1985 Kawasaki Eliminator ZL900 w/2003 ZRX1200 Stage 3
    Florida Swamp
    Plastic gears ........... or nylon gears?
    2019 F3-S , Black & Silver
    May 2024
    Massachusetts
    I assumed they were plastic. You know what they say about assumptions. I'm speaking of the OEM gears.
    Previous Rides
    We've only seen failure due to improper service installs (usually water pump related). Not to say that they don't fail naturally. Just not sure how concerned we should be about it?!
    I have 87.5K+ on mine with no problems whatsoever with anything related to the engine and only one warranty repair item, parking brake motor replaced under factory warranty. My B.E.S.T. extended warranty expired unused.
    May 2024
    Massachusetts
    Well that makes me a little more comfortable. Thank you both for your replies
    Previous Rides
    Bossier LoUiSiAna
    Both of the issues referenced in this link were 998 V-Twins. Not sure this relates meaningfully to the 1330 motors.
    Mar 2015
    forrest above Reno, Nv
    When I replaced the water pump in my 2014 RTS, I discovered the plastic gear. I didn't like that, but it hasn't caused many problems on the tens of thousands out there. I'm not concerned about it. On mine the thermostat failed, breaking into 2 pieces. The thermostat and water pump are one unit.
    Lew L
    2014 RTS , Circuit Yellow
    Active Member AndysF3S's Avatar
    Jul 2023
    Alberta
    I haven't owned my Spyder long enough to have any history on the nylon gears but I do know that they were used by GM in some of the car engines (cam shaft sprocket - metal hub with a nylon running surface) to provide for a quieter running timing chain. Yes they did wear but I didn't experience any failures with the teeth chipping or breaking off even with 5500-6000 RPM in a drag race.
    Bossier LoUiSiAna
    Agree but still plastic, not beyond reasonable would continue to use on new engines
    SoFlo
    Could purchase a brand new gear. Model it in a CAD program, then 3D print them in steel.
    Simply an idea.
